Configuring a Floating Head
- Aldenflorio
- Thank you received: 15
21 Sep 2020 03:54 #183040
by Aldenflorio
Replied by Aldenflorio on topic Configuring a Floating Head
i opened it bc it was a link and i copied everything in there and pasted it in /home/user/linuxcnc/configs/the_plasmac_cutter/the_plasmac_cutter_connections.hal
i just did it again to be certain
- phillc54
- Thank you received: 2100
21 Sep 2020 03:56 #183041
by phillc54
Replied by phillc54 on topic Configuring a Floating Head
What was a link?
What command are you using to run linuxcnc?
- Aldenflorio
21 Sep 2020 04:01 #183043
by Aldenflorio
When i open the file you posted it takes me to here
www.forum.linuxcnc.org/media/kunena/atta...tter_connections.hal
I'm opening linux from a shortcut that is created when i go to applications>CNC>Linuxcnc>the_plasmac_cutter> and check the box "create shortcut"
im not sure what you mean by what command am i using to run linuxcnc
- phillc54
21 Sep 2020 04:05 #183044
by phillc54
You could right click the attachment and save it directly.
Try from a terminal:
linuxcnc ~/linuxcnc/configs/the_plasma_cutter/the_plasma_cutter.iniPlease Log in or Create an account to join the conversation.
- Aldenflorio
21 Sep 2020 04:28 - 21 Sep 2020 04:28 #183046
by Aldenflorio
It only says save as link. when i run that in the terminal i get this
user@debian:~$ linuxcnc ~/linuxcnc/configs/the_plasmac_cutter/the_plasmac_cutter.ini
LINUXCNC - 2.8.0-39-g76260b4f7
Machine configuration directory is '/home/user/linuxcnc/configs/the_plasmac_cutter'
Machine configuration file is 'the_plasmac_cutter.ini'
Starting LinuxCNC...
twopass:invoked with <> options
twopass:found ./the_plasmac_cutter.hal
twopass:found ././plasmac/plasmac.tcl
twopass:found ./the_plasmac_cutter_connections.hal
Note: Using POSIX realtime
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
iptables: No chain/target/match by that name.
hm2_eth: 10.10.10.10: Hardware address: 00:60:1b:16:01:29
hm2_eth: discovered 7I96
hm2/hm2_7i96.0: Smart Serial Firmware Version 43
hm2/hm2_7i96.0: 51 I/O Pins used:
hm2/hm2_7i96.0: IO Pin 000 (TB3-01): IOPort
hm2/hm2_7i96.0: IO Pin 001 (TB3-02): IOPort
hm2/hm2_7i96.0: IO Pin 002 (TB3-03): IOPort
hm2/hm2_7i96.0: IO Pin 003 (TB3-04): IOPort
hm2/hm2_7i96.0: IO Pin 004 (TB3-05): IOPort
hm2/hm2_7i96.0: IO Pin 005 (TB3-06): IOPort
hm2/hm2_7i96.0: IO Pin 006 (TB3-07): IOPort
hm2/hm2_7i96.0: IO Pin 007 (TB3-08): IOPort
hm2/hm2_7i96.0: IO Pin 008 (TB3-09): IOPort
hm2/hm2_7i96.0: IO Pin 009 (TB3-10): IOPort
hm2/hm2_7i96.0: IO Pin 010 (TB3-11): IOPort
hm2/hm2_7i96.0: IO Pin 011 (TB3-13/TB3-14): SSR #0, pin Out-00 (Output)
hm2/hm2_7i96.0: IO Pin 012 (TB3-15/TB3-16): SSR #0, pin Out-01 (Output)
hm2/hm2_7i96.0: IO Pin 013 (TB3-17/TB3-18): SSR #0, pin Out-02 (Output)
hm2/hm2_7i96.0: IO Pin 014 (TB3-19/TB3-20): SSR #0, pin Out-03 (Output)
hm2/hm2_7i96.0: IO Pin 015 (TB3-21/TB3-22): SSR #0, pin Out-04 (Output)
hm2/hm2_7i96.0: IO Pin 016 (TB3-23/TB3-24): SSR #0, pin Out-05 (Output)
hm2/hm2_7i96.0: IO Pin 017 (TB1-02/TB1-03): StepGen #0, pin Step (Output)
hm2/hm2_7i96.0: IO Pin 018 (TB1-04/TB1-05): StepGen #0, pin Direction (Output)
hm2/hm2_7i96.0: IO Pin 019 (TB1-08/TB1-09): StepGen #1, pin Step (Output)
hm2/hm2_7i96.0: IO Pin 020 (TB1-10/TB1-11): StepGen #1, pin Direction (Output)
hm2/hm2_7i96.0: IO Pin 021 (TB1-14/TB1-15): StepGen #2, pin Step (Output)
hm2/hm2_7i96.0: IO Pin 022 (TB1-16/TB1-17): StepGen #2, pin Direction (Output)
hm2/hm2_7i96.0: IO Pin 023 (TB1-20/TB1-21): StepGen #3, pin Step (Output)
hm2/hm2_7i96.0: IO Pin 024 (TB1-22-TB1-23): StepGen #3, pin Direction (Output)
hm2/hm2_7i96.0: IO Pin 025 (TB2-01/TB2-03): StepGen #4, pin Step (Output)
hm2/hm2_7i96.0: IO Pin 026 (TB2-04/TB2-05): StepGen #4, pin Direction (Output)
hm2/hm2_7i96.0: IO Pin 027 (TB2-07/TB2-08): Encoder #0, pin A (Input)
hm2/hm2_7i96.0: IO Pin 028 (TB2-10/TB2-11): Encoder #0, pin B (Input)
hm2/hm2_7i96.0: IO Pin 029 (TB2-13/TB2-14): Encoder #0, pin Index (Input)
hm2/hm2_7i96.0: IO Pin 030 (TB2-16/TB2-17): IOPort
hm2/hm2_7i96.0: IO Pin 031 (TB2-18/TB2-19): IOPort
hm2/hm2_7i96.0: IO Pin 032 (internal): IOPort
hm2/hm2_7i96.0: IO Pin 033 (internal): SSR #0, pin AC Ref (internal) (Output)
hm2/hm2_7i96.0: IO Pin 034 (P1-01): IOPort
hm2/hm2_7i96.0: IO Pin 035 (P1-02): IOPort
hm2/hm2_7i96.0: IO Pin 036 (P1-03): IOPort
hm2/hm2_7i96.0: IO Pin 037 (P1-04): IOPort
hm2/hm2_7i96.0: IO Pin 038 (P1-05): IOPort
hm2/hm2_7i96.0: IO Pin 039 (P1-06): IOPort
hm2/hm2_7i96.0: IO Pin 040 (P1-07): IOPort
hm2/hm2_7i96.0: IO Pin 041 (P1-08): IOPort
hm2/hm2_7i96.0: IO Pin 042 (P1-09): IOPort
hm2/hm2_7i96.0: IO Pin 043 (P1-11): IOPort
hm2/hm2_7i96.0: IO Pin 044 (P1-13): IOPort
hm2/hm2_7i96.0: IO Pin 045 (P1-15): IOPort
hm2/hm2_7i96.0: IO Pin 046 (P1-17): IOPort
hm2/hm2_7i96.0: IO Pin 047 (P1-19): IOPort
hm2/hm2_7i96.0: IO Pin 048 (P1-21): IOPort
hm2/hm2_7i96.0: IO Pin 049 (P1-23): IOPort
hm2/hm2_7i96.0: IO Pin 050 (P1-25): IOPort
hm2/hm2_7i96.0: registered
twopass: Error in file ./the_plasmac_cutter_connections.hal:
Pin 'hm2_7i96.gpio.009.in' does not exist
hm2_eth: HostMot2 ethernet driver unloaded
hm2: unloading
LinuxCNC terminated with an error. You can find more information in the log:
/home/user/linuxcnc_debug.txt
and
/home/user/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
Last edit: 21 Sep 2020 04:28 by Aldenflorio.
- phillc54
21 Sep 2020 04:33 #183047
by phillc54
In a terminal type this:
Then attach the connections.txt file created in your home directory to your next post.
cat ~/linuxcnc/configs/the_plasma_cutter/the_plasma_cutter_connections.hal > ~/connections.txtThen attach the connections.txt file created in your home directory to your next post.
- Thank you received: 5316
21 Sep 2020 04:34 #183048
Correct pin name is:
hm2_7i96.0,gpio.009.in
Replied by PCW on topic Configuring a Floating Head
- phillc54
21 Sep 2020 04:36 #183049
by phillc54
forum.linuxcnc.org/49-basic-configuratio...head?start=70#183023
He has supposedly edited it, but still getting the same error:
- Aldenflorio
21 Sep 2020 04:43 #183050
by Aldenflorio
here it is. yes i have edited it. im sure you dindt intend for the comma but nonetheless i tried that as well (didn't work)
- phillc54
21 Sep 2020 04:45 #183052
by phillc54
This is from the file you just posted:
ALL the input pins are wrong, you must be editing a different file to this one.
net plasmac:arc-ok-in hm2_7i96.gpio.009.in => db_arc-ok.in
net plasmac:float-switch hm2_7i96.gpio.03.in => db_float.in
# net plasmac:breakaway {YOUR BREAKAWAY PIN} => db_breakaway.in
# net plasmac:ohmic-probe {YOUR OHMIC PROBE PIN} => db_ohmic.in
# net plasmac:ohmic-enable plasmac.ohmic-enable => {YOUR OHMIC ENABLE PIN}
net plasmac:torch-on => hm2_7i96.0.ssr.00.out-02
net plasmac:move-up hm2_7i96.gpio.010.in => plasmac.move-up
net plasmac:move-down hm2_7i96.gpio.008.in => plasmac.move-downALL the input pins are wrong, you must be editing a different file to this one.
Time to create page: 0.422 seconds
