Configuring a Floating Head
- phillc54
- Thank you received: 2100
16 Sep 2020 05:37 #182369
by phillc54
Edit your HAL file, change this line:
to:
In this HAL file you have a line:
In plasma_cutter_connections.hal you also have a line somewhere with hm2_7i96.0.gpio.003.in
So one of these lines is pointing to the wrong input, it needs to be changed.
Replied by phillc54 on topic Configuring a Floating Head
I'm not sure i understand what you're asking me to do, sorry
net dout-01 <= motion.digital-out-01to:
#net dout-01 <= motion.digital-out-01In this HAL file you have a line:
net max-home-z <= hm2_7i96.0.gpio.003.inIn plasma_cutter_connections.hal you also have a line somewhere with hm2_7i96.0.gpio.003.in
- Aldenflorio
- Thank you received: 15
16 Sep 2020 06:01 - 16 Sep 2020 06:03 #182371
by Aldenflorio
Replied by Aldenflorio on topic Configuring a Floating Head
Ok, so I looked at what you said. Well I wanted to be sure I got the right thing to put into the pin section of plasmac. So I made up an output for so could go into the Hal file of my preexisting machine and copy it and past into the plasmac. Along with that I only have one limit switch for the z axis. And in order to have all the joints home together I set the limit switch as home. So I guess when it loaded my preexisting machines files it butted heads with the already existing inputs. So what I just did was went back into pnccof and just set those pins to unused. Now I am getting this error message, but gladevcp also popped up. Sorry for the pictures but it won’t let my copy the text for some reason
imgur.com/a/QSQ93pZ
imgur.com/a/QSQ93pZ
Last edit: 16 Sep 2020 06:03 by Aldenflorio.
- phillc54
16 Sep 2020 06:09 #182373
by phillc54
In the ini file there is a line starting with "GLADEVCP =" and in that line there is "gvcp_call_list".
Comment out that line by adding # as the first character of the line.
- Aldenflorio
16 Sep 2020 06:16 #182374
by Aldenflorio
i cant seem to find that line
- phillc54
16 Sep 2020 06:17 - 16 Sep 2020 06:17 #182375
by phillc54
Can you post your ini file
Actually, check in post gui.hal
Last edit: 16 Sep 2020 06:17 by phillc54.
- Aldenflorio
16 Sep 2020 06:17 #182376
by Aldenflorio
I did
- Aldenflorio
16 Sep 2020 06:21 #182377
by Aldenflorio
i cant find post gui.hal
- phillc54
16 Sep 2020 06:21 #182379
by phillc54
Well if you found it in the ini file then that is where it needs to be fixed.
- Aldenflorio
16 Sep 2020 06:24 - 16 Sep 2020 06:24 #182380
by Aldenflorio
Ill keep looking in the ini files
Last edit: 16 Sep 2020 06:24 by Aldenflorio.
- phillc54
16 Sep 2020 06:25 #182381
by phillc54
Can you compress your config and post it here
Time to create page: 0.522 seconds
