Configuring a Floating Head
6 years 1 month ago #182197 by rodw
Replied by rodw on topic Configuring a Floating Head
Aldenflorio wrote: I have 2.8 now, maybe thats why I'm getting that error message. nonetheless theres still no plasmac
You should find Plasmac under the sims. It does not get installed for you.
6 years 1 month ago - 6 years 1 month ago #182248 by Aldenflorio
I don’t know where sims is. Sorry I’m not very familiar with any of this.
Last edit: 6 years 1 month ago by Aldenflorio.
6 years 1 month ago #182298 by phillc54
None of those messages above are related to LinuxCNC, do you have the linuxcnc repository in /etc/apt/sources.list or any of the /etc/apt/sources.list.d/ files
If it is a new installation then you need to setup a PlasmaC config yourself:
linuxcnc.org/docs/2.8/html/plasma/plasma..._installing_linuxcnc
linuxcnc.org/docs/2.8/html/plasma/plasma..._to_the_base_machine
If you want to try a PlasmaC sim then run LinuxCNC and you will get a config selector, PlasmaC is in Sample Configurations >> by_machine >> plasmac
6 years 1 month ago - 6 years 1 month ago #182312 by Aldenflorio
i have Linuxcnc.list and Linuxcnc.list.save. I also have base.list and base.list.save but im not sure if those pertain to linuxcnc.
When i do this command: $ python /usr/share/doc/linuxcnc/examples/sample-configs/by_machine/plasmac/configurator.py
i get this: bash: $: command not found
6 years 1 month ago #182313 by phillc54
What are the contents of linuxcnc.list and base.list files?
Could you also post the result of uname -a from a terminal
6 years 1 month ago - 6 years 1 month ago #182314 by Aldenflorio
Linuxcnc.list
# deb http://linuxcnc.org/ stretch base # deb-src http://linuxcnc.org/ stretch base # deb http://linuxcnc.org/ stretch 2.7-uspace # deb-src http://linuxcnc.org/ stretch 2.7-uspace deb http://buildbot.linuxcnc.org/ stretch 2.8-rtpreempt deb-src http://buildbot.linuxcnc.org/ stretch 2.8-rtpreempt
base.list
deb http://ftp.debian.org/debian/ stretch main # deb-src http://ftp.debian.org/debian/ stretch main
How do i do uname? if i just type uname in the terminal i get linux
Time to create page: 0.117 seconds
