Configuring a Floating Head
6 years 1 month ago - 6 years 1 month ago #182397 by Aldenflorio
I may have accidentally lied. So I have a picture I converted into g-code, I plugged that in to see if it all worked. My z axis isn’t moving though. It didn’t move at all. I was expecting a touch off as is suppose to happen with a floating head but nothing. I may just have converted the g code wrong. All the Inkscape videos are weird
Last edit: 6 years 1 month ago by Aldenflorio.
6 years 1 month ago #182398 by phillc54
You need a spindle o on command to start the probe sequence. PlasmaC remove all Z commands as it handle all the Z axis height.
Open one of the example files made for Plasmac, they are installed with LinuxCNC.
6 years 1 month ago - 6 years 1 month ago #182401 by Aldenflorio
I can’t find them. Is there a link to download them?
6 years 1 month ago #182403 by phillc54
When you go to open a file they should be in a subdirectory named plasmac.
Their real location is /usr/share/linuxcnc/ncfiles/plasmac/
6 years 1 month ago #182404 by Aldenflorio
Thank you
6 years 1 month ago - 6 years 1 month ago #182990 by Aldenflorio
Hello, I'm back again with some more issues. we got the configuration working and everything,last time. and i finally got the design program all worked out and the g-code worked out. So naturally its testing time. Today was going to be the firs cut but everything would go right until the torch had to fire. Which it wouldnt do, so i thought about it a bit and realized i put the torch fire on the wrong output when setting up plsamc. so i went back to reconfigure it, well i typed it wrong and now it wont let me reconfigure. im getting these error messages
When opening Linuxcnc:
(i was going to copy and paste it here but for some reason i cant copy or paste erro messages from linux so there are picture linked) imgur.com/a/gpia5al
When i try to edit the plasmac again:
Traceback (most recent call last): File "linuxcnc/configs/plasma_cutter/configurator.py", line 517, in on_create_clicked self.reconfigure() File "linuxcnc/configs/plasma_cutter/configurator.py", line 1801, in reconfigure shutil.copy(newConex, oldConex) File "/usr/lib/python2.7/shutil.py", line 119, in copy copyfile(src, dst) File "/usr/lib/python2.7/shutil.py", line 83, in copyfile with open(dst, 'wb') as fdst: IOError: [Errno 13] Permission denied: '/home/user/linuxcnc/configs/plasma_cutter/plasma_cutter_connections.hal.bakr'
Time to create page: 0.062 seconds
