Configuring a Floating Head
6 years 1 month ago #182991 by phillc54
That mentions a permissions issue, did you do something as sudo.
6 years 1 month ago #182995 by Aldenflorio
Yeah, it gives me that message when I press reconfigure on the plasmac config panel. i tried opening up the plasmac config panel with sudo before it like this, but get this message when i press reconfigure:
user@debian:~$ sudo python linuxcnc/configs/plasma_cutter/configurator.py linuxcnc/configs/plasma_cutter/configurator.py:2442: GtkWarning: Attempting to store changes into `/root/.local/share/recently-used.xbel', but failed: Failed to create file '/root/.local/share/recently-used.xbel.B4DJR0': No such file or directory gtk.main() linuxcnc/configs/plasma_cutter/configurator.py:2442: GtkWarning: Attempting to set the permissions of `/root/.local/share/recently-used.xbel', but failed: No such file or directory gtk.main()
6 years 1 month ago #183002 by phillc54
That is because it is looking for the home directory for the root user and it does not exist.
You do NOT need to be the root user to create or modify any LinuxCNC configuration. Doing so WILL cause issues.
Run this as the normal user:
sudo chown -R user:user ~/linuxcnc/configs/
Then run the Configurator as a normal user:
python ~/linuxcnc/configs/plasma_cutter/configurator.py
6 years 1 month ago #183007 by Aldenflorio
Ok it seems to have let me reconfigure the plasmac then. But I get the same error message when opening linuxcnc. The only thing that’s different is the debugging information which is the following:
Note: Using POXIS realtime
Iptable: No chain/target/match by that name.
1468
Stopping realtime threads
Unloading Hal components
Note: Using POSIX realtime
6 years 1 month ago #183014 by phillc54
Can you post the complete terminal output from when you try to run linuxcnc
6 years 1 month ago - 6 years 1 month ago #183019 by Aldenflorio
It won’t let me copy and paste. So I have to do picture. Sorry I open it up through a desktop shortcut
imgur.com/a/vQktDeh
Last edit: 6 years 1 month ago by Aldenflorio.
Time to create page: 0.192 seconds
