- Thank you received: 5334
Configuring a Floating Head
6 years 1 month ago #183048
Correct pin name is:
hm2_7i96.0,gpio.009.in
Replied by PCW on topic Configuring a Floating Head
Pin 'hm2_7i96.gpio.009.in' does not exist
6 years 1 month ago #183049
by phillc54
forum.linuxcnc.org/49-basic-configuratio...head?start=70#183023
Replied by phillc54 on topic Configuring a Floating Head
- Aldenflorio
- Topic Author
- Thank you received: 15
6 years 1 month ago #183050
by Aldenflorio
Replied by Aldenflorio on topic Configuring a Floating Head
here it is. yes i have edited it. im sure you dindt intend for the comma but nonetheless i tried that as well (didn't work)
6 years 1 month ago #183052
by phillc54
This is from the file you just posted:
ALL the input pins are wrong, you must be editing a different file to this one.
net plasmac:arc-ok-in hm2_7i96.gpio.009.in => db_arc-ok.in
net plasmac:float-switch hm2_7i96.gpio.03.in => db_float.in
# net plasmac:breakaway {YOUR BREAKAWAY PIN} => db_breakaway.in
# net plasmac:ohmic-probe {YOUR OHMIC PROBE PIN} => db_ohmic.in
# net plasmac:ohmic-enable plasmac.ohmic-enable => {YOUR OHMIC ENABLE PIN}
net plasmac:torch-on => hm2_7i96.0.ssr.00.out-02
net plasmac:move-up hm2_7i96.gpio.010.in => plasmac.move-up
net plasmac:move-down hm2_7i96.gpio.008.in => plasmac.move-down
- Aldenflorio
- Topic Author
6 years 1 month ago #183058
by Aldenflorio
I feel pretty bad.
So I opens the config folder from file manager and I created a link. So I suppose when I edited the file and saved it it didn’t update the “parent” file. I didn’t think about it bc it has worked for me before. I’m really sorry that I took you through all this. It worked once I did it through the file manager itself
6 years 1 month ago #183060
by phillc54
Great, glad you got it going, I was running out of ideas.
Time to create page: 0.164 seconds
