- Thank you received: 2100
Configuring a Floating Head
6 years 1 month ago - 6 years 1 month ago #183023
by phillc54
Replied by phillc54 on topic Configuring a Floating Head
In the first picture:
Try:
You can directly edit the_plasma_cutter_connection.hal file to fix it
Pin hm2_7i96.gpio.009.in does not exist
Try:
hm2_7i96.0.gpio.009.in
Last edit: 6 years 1 month ago by phillc54. Reason: typo
- Aldenflorio
- Topic Author
- Thank you received: 15
6 years 1 month ago #183027
by Aldenflorio
Replied by Aldenflorio on topic Configuring a Floating Head
I edited it to where the line reads this:
net plasmac:arc-ok-in hm2_7i96.0.gpio.009.in => db_arc-ok.in
I still get an error message. I’ll have to do pictures again. Could a problem be if I have more then one machine config?
imgur.com/a/n2ljnko
imgur.com/a/n2ljnko
6 years 1 month ago #183028
by phillc54
Multiple configs are no problem.
Did you check completely through the file to make sure that pin name does not appear somewhere else?
- Aldenflorio
- Topic Author
6 years 1 month ago #183029
by Aldenflorio
I just checked the ini file, the Hal file, and the Hal connections file. It’s not repeated. Should I zip my config over?
6 years 1 month ago #183030
by phillc54
Yep, zip it and post it here.
- Aldenflorio
- Topic Author
6 years 1 month ago #183032
by Aldenflorio
here it is
Time to create page: 0.065 seconds
