hy vfd rs 485 gmoccapy
- Thank you received: 7509
24 Jul 2021 08:59 #215779
Replied by tommylight on topic hy vfd rs 485 gmoccapy
Search for "arduino usb permission denied".
- billykid
- Thank you received: 83
24 Jul 2021 09:00 #215780
by billykid
Replied by billykid on topic hy vfd rs 485 gmoccapy
italy
- snowgoer540
- Thank you received: 907
24 Jul 2021 09:03 - 24 Jul 2021 09:03 #215782
by snowgoer540
Replied by snowgoer540 on topic hy vfd rs 485 gmoccapy
Tommy, do you use a locale other than English when you set up machines? (Especially ones where thc-feed-rate remains zero despite being on a later version of QtPlasmaC)?
sorry to “borrow” this thread, but since it came up here…
Last edit: 24 Jul 2021 09:03 by snowgoer540.
- Pauchuk
24 Jul 2021 09:14 #215784
by Pauchuk
Replied by Pauchuk on topic hy vfd rs 485 gmoccapy
I tried to run on live debian, then I had an error: permission denied. After installation it allows to use USB`sSearch for "arduino usb permission denied".
24 Jul 2021 12:55 #215799
Nah, always English, even keyboard is always English despite having all kinds of layouts.
What should i use? Albanian is not an option !Tommy, do you use a locale other than English when you set up machines?
24 Jul 2021 12:56 #215800
It will still not work on Linux, the current user has to be added to the "dialout" group.
- Pauchuk
24 Jul 2021 18:02 #215812
by Pauchuk
dialout:x:20: my user name..
So, this is done too..
$ getent group dialout
- Pauchuk
25 Jul 2021 08:15 #215853
by Pauchuk
Just got another HY VFD, same thing. So up until now, I have used 2 PC`s, linuxcnc 2.7, linuxcnc with update, linuxcnc 2.8 and got same error - error reading setup from VFD.. What should I do next?
- Thank you received: 2177
25 Jul 2021 10:18 #215861
Replied by Aciera on topic hy vfd rs 485 gmoccapy
I presume you can see your RS485 adaptor with terminal command?
lsusbPlease Log in or Create an account to join the conversation.
- Pauchuk
25 Jul 2021 10:22 - 25 Jul 2021 10:26 #215862
by Pauchuk
sudo apt-get update and then, again apt-get install usbutils, same error - no candidatelsusb Command not found. I tried apt-get install usbutils Gives me: 'usbtutils' has no installation candidate.. I run
Last edit: 25 Jul 2021 10:26 by Pauchuk.
Time to create page: 0.506 seconds
