hy vfd rs 485 gmoccapy
25 Jul 2021 10:42 - 25 Jul 2021 10:45 #215865 by Aciera
Replied by Aciera on topic hy vfd rs 485 gmoccapy
Hm, ok let's try this, unplug your RS485 adaptor and plug it in again.
Then run this in a terminal window and post maybe the last page of the output. This should give you information of the device you connected last:
dmesg | awk '/tty/ && /USB/ {print "/dev/"$10}'|tail-1
Last edit: 25 Jul 2021 10:45 by Aciera. Reason: typo in command!
25 Jul 2021 10:52 #215867 by Aciera
Reinstalled wheezy, didnt update to 2.8. Same error reading setup from VFD
Just noticed this. Is there any particular reason you are not using the current official debian buster ISO?
www.linuxcnc.org/iso/linuxcnc-2.8.0-buster.iso
25 Jul 2021 10:53 #215868 by Pauchuk
Replied by Pauchuk on topic hy vfd rs 485 gmoccapy
Yes, I had bad latency results on buster.
25 Jul 2021 10:55 #215869 by Pauchuk
tail-1: command not found
25 Jul 2021 11:02 #215871 by Aciera
Let's try again. Unplug then reconnect and post result of this command:
sudo dmesg | grep 'USB'
25 Jul 2021 11:08 #215872 by Pauchuk
[    3.392617] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.392740] ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus number 1
[    3.408055] ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00
[    3.408097] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    3.408101] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.408300] hub 1-0:1.0: USB hub found
[    3.408516] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 2
[    3.420539] uhci_hcd: USB Universal Host Controller Interface driver
[    3.424032] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[    3.424096] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    3.424100] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.424281] hub 2-0:1.0: USB hub found
[    3.730185] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 3
[    3.730276] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[    3.730280] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.730553] hub 3-0:1.0: USB hub found
[    3.730702] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 4
[    3.730790] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[    3.730794] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.731076] hub 4-0:1.0: USB hub found
[    3.731644] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 5
[    3.731723] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[    3.731728] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.732195] hub 5-0:1.0: USB hub found
[    3.732357] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 6
[    3.732437] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[    3.732441] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.732938] hub 6-0:1.0: USB hub found
[    3.733100] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 7
[    3.733199] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[    3.733203] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.733380] hub 7-0:1.0: USB hub found
[    4.044035] usb 6-1: new low-speed USB device number 2 using uhci_hcd
[    4.220440] usb 6-1: New USB device found, idVendor=1c4f, idProduct=0002
[    4.220446] usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    4.242163] generic-usb 0003:1C4F:0002.0001: input,hidraw0: USB HID v1.10 Keyboard [SEM HCT Keyboard] on usb-0000:00:1d.1-1/input0
[    4.262491] generic-usb 0003:1C4F:0002.0002: input,hidraw1: USB HID v1.10 Device [SEM HCT Keyboard] on usb-0000:00:1d.1-1/input1
[    4.262541] usbhid: USB HID core driver
[    4.332044] usb 6-2: new low-speed USB device number 3 using uhci_hcd
[    4.509445] usb 6-2: New USB device found, idVendor=413c, idProduct=301a
[    4.509453] usb 6-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    4.509459] usb 6-2: Product: Dell MS116 USB Optical Mouse
[    4.524993] input: PixArt Dell MS116 USB Optical Mouse as /devices/pci0000:00/0000:00:1d.1/usb6/6-2/6-2:1.0/input/input2
[    4.525113] generic-usb 0003:413C:301A.0003: input,hidraw2: USB HID v1.11 Mouse [PixArt Dell MS116 USB Optical Mouse] on usb-0000:00:1d.1-2/input0
[    4.636043] usb 7-2: new full-speed USB device number 2 using uhci_hcd
[    4.799202] usb 7-2: New USB device found, idVendor=1a86, idProduct=7523
[    4.799209] usb 7-2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[    4.799214] usb 7-2: Product: USB2.0-Ser!
[   11.732574] USB Serial support registered for generic
[   11.732604] usbserial: USB Serial Driver core
[   11.739064] USB Serial support registered for ch341-uart
[   11.752364] usb 7-2: ch341-uart converter now attached to ttyUSB0
[ 2032.280074] usb 7-2: USB disconnect, device number 2
[ 2032.280298] ch341-uart ttyUSB0: ch341-uart converter now disconnected from ttyUSB0
[ 2034.008034] usb 7-2: new full-speed USB device number 3 using uhci_hcd
[ 2034.171367] usb 7-2: New USB device found, idVendor=1a86, idProduct=7523
[ 2034.171373] usb 7-2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 2034.171379] usb 7-2: Product: USB2.0-Ser!
[ 2034.187521] usb 7-2: ch341-uart converter now attached to ttyUSB0
25 Jul 2021 11:10 - 25 Jul 2021 11:11 #215873 by Aciera
what does this report:
ls -l /dev/ttyUSB0
Last edit: 25 Jul 2021 11:11 by Aciera.
25 Jul 2021 11:12 #215874 by Pauchuk
ls -l /dev/ttyUSB0
pauls@debian:~$ ls -l /dev/ttyUSB0
crw-rw---T 1 root dialout 188, 0 Jul 25 11:54 /dev/ttyUSB0
25 Jul 2021 11:14 #215875 by Aciera
and what does this report:
groups
25 Jul 2021 11:16 #215876 by Pauchuk
groups
pauls@debian:~$ groups
pauls dialout cdrom floppy sudo audio dip video plugdev staff fuse scanner bluetooth netdev
Time to create page: 0.178 seconds
