Random stuff, reduction, servo motors, ideas and thoughts
- Thank you received: 7501
And as i've read several times here on this forum, it will need another power supply of 12-24V to work, besides 5V.
Enjoy ...
- Mike_Eitel
- Thank you received: 183
If you gueas a Power loss of 25% of your max power - > that will be your "heater" equivalent.
m5c
Mike
- machinedude
- Thank you received: 312
part of the reason i did not like the small enclosure was lack of spacing but i'm on a tight budget at the moment.
i have a 24V power supply but don't think i need it with just the step and direction. this bob does take a 12V to 24V if you want to use the relay for a spindle.
this is just going to be very basic for right now. i just want things to move
correction i will need the 24V power supply for the fans i have
- Mike_Eitel
- machinedude
- Mike_Eitel
Gets you creative which in my eyes is not the whorsest
Just prepare the openings now, you could eventually use a fan out of an old pc-powersuply.
Mike
- Clive S
- Thank you received: 486
No. it still needs 12-24 V for the inputs to work. As well as the 5V
- machinedude
the last bob i had was just a mother board made for Gecko drives.it was nothing more than the step and direction logic signal and a DC connection for the motors. plug and play in it's simplest form.
the only thing i seen about this one or one that looks just like it was the 5V supply coming from the USB. i guess not all computers use a 5V and some are only around 3.3V in that case a dedicated 5V supply is needed. i will have to see if i can find something more on the 24V side of it. i thought the 24V side was just for spindle control, E stop and limit switches but i could be mistaken.
- Clive S
P/Ports used to be 5 volts but I believe most now are 3.3 volts.
12v connected to the Bob will make the inputs work and the spindle.
- machinedude
once i get it down to the the computer i can check voltages on the bob connections i'm just not that far along yet. with the holidays all my parts came in Thursday evening and I spent most of my time since trying to figure out the best way to fit all this crap into a small box
i think i got the control signal sorted out i just need to move things to the machine and connect the motors to the drives. then i can see if i need to add power supplies or not.
basically it just depends on the computer at this point and until i get things down there i don't were i will land on that side of things just yet
i'm not a fan of wiring things up
