forum.linuxcnc.org/forum/18-computer/259...success?limitstart=0
Previously promised link. Im wanting to use this computer due to lack of funds and its actually a pretty solid build for a laptop.
I was contemplating spending $25 dollars to upgrade the cpu to a t9300, which should reduce heat output of the cpu, and be a little bit safer to run smictrl.
I have copper sheet, i think would be useful for added heat displacement. A peice over the cpu, and a peice over the gpu, should help a lot plus the cooler cpu. ( for $25 outta pocket this is a good move, i think.)
does anyone feel the cpu change would hurt latency? Its a boost in cpu power by .3 plus much lower heat.
Plus i have some ddr3 2x4gb ram that may work. it cant hurt on a trial run.
all things on hand, minus the paste and cpu, this shouldnt set me back much.
One thing i was waiting on buying was the breakout board. consider my output will be about 3.5v, is there a breakout board that anyone would suggest?
thanks in advance,
jason
