ubuntu 14.04.1 linuxcnc help
10 years 10 months ago #66257 by Razor_keen
I wanted to add, that i tried using isoclpus and idle=poll independently and for some wierd reason, they work best with both of them in boot parameters. Its actually a great decrease in latency using them both. they are conffigured with idle=poll first then isoclpus second, plus im running scripts to make the most use of isoclpus by further limiting interupts to one core, leaving the other free to process userspace? I think this is how it works. Anyways, latency is at ~8000 and ~14000 with five instances of glxgears running and a cd playing. usb spikes the latency, but copying from the hard drive to the harddrive has little effect. Some of the computers specs are 2.2 ghz cpu 2gb ram, nvidia graphiics (140? or 340?.. something with a 40)
This is why i was mentioning the t9300 as a possible cpu upgrade, plus i could overclock it safely, and upgrade the ram, if the computer will accept ddr3, as i think its ddr2 natively.
i think i could squeeze every bit of performance out of this thing safely if i do it right...
10 years 10 months ago #66258 by tjmarch
I deal with six axis robots used mostly in auto industry. In my job I program Fanuc robots price is way out of everyone's range unless maybe refurb.
I assume that you are going to use stepper motors and not servo motors scene you are going parallel port direction. I do not know what amp range of driver you are going to use.
This below web site has allot of hobby based electronics
www.pololu.com/category/9/motion-control-modules
The next has a little more robust resources which I bought most of my mechanical stuff
openbuildspartstore.com/
I also bought some electronics from
us.stepperonline.com/
Tim
10 years 10 months ago #66259 by Razor_keen
No eBay APP ID and/or Cert ID defined in Kunena configurationIt seems like a much better bet over the cheap chinese boards although tis one seemed pretty full featured for a cheap board...
10 years 10 months ago #66261 by Razor_keen
The drivers i built are supposed to handle 3a without heatsinks and up to 5 if cooled properly. they literally came out of the same printers i robbed the steppers from. makes sense that if the printer has a good motor then it has the electronics to drive them as well.
In all actuallity they had a part that was better than the others and cheap to boot so i simply ordered two more and built three matching drivers. so, the answer is max 3 to 5a, nema 17 and 23 steppers.
10 years 10 months ago #66263 by tjmarch
I can see why you would want the pendent to teach robot arms with manual gcode entry which will be a tough way to go but I do not know of another way for robot path to be entered using linuxcnc. With a industrial robot you move the robot using a teach pendent and once you have it where you want it you record that position. With a set of parameters for each point then with multi-pull points to create a path.
Tim
10 years 10 months ago - 10 years 10 months ago #66264 by Razor_keen
I do have some dc motors and radial optical encoders, i wanted to make something cool out of. I was even considering using on for the z axis because it would have been a bit more powerful geared, only i was afraid i might not encase it properly and it could get dust, or chips inside of it, ruining the performance. Plus they would have required a much tighter latency requirement.
Thats not to say they wouldnt be useful in other applications.
My current plan is to go with arduino for the robot arm, and set parameters to govern the more comlex motions, down to a simple 8 button input sceme for my kids to play with. (foward, back, rotate left, right, up, down, grab,release.)
Kinda like a really cool claw machine game.
(plus the basic arduino controllers come with eight buttons, so seems to make sense to stick with what you can get lol.)
Last edit: 10 years 10 months ago by Razor_keen.
Time to create page: 0.401 seconds
