Complete HOW-TO Linux Mint 18.1 32/64 RTAI or PREEMPT with RIP install or deb
04 Apr 2017 01:41 #90840 by Elroy
Wow!!
my unmet dependencies are mutiplying!! What on earth did i do?
elroy@elroy-Lenovo-V570 ~ $ dpkg-checkbuilddeps
dpkg-checkbuilddeps: error: Unmet build dependencies: cdbs (>= 0.4.41) gnome-pkg-tools (>= 0.10) libxml2-dev libart-2.0-dev (>= 2.3.16-5) libglade2-dev (>= 2.3.6-4) libgnomecanvas2-dev (>= 2.14.0-2) libgnomeprint2.2-dev (>= 2.12) gtk-doc-tools intltool (>= 0.35.0) libglib2.0-doc libgtk2.0-doc
  • cncnoob1979
  • cncnoob1979's Avatar Topic Author
  • Platinum Member
  • Platinum Member
04 Apr 2017 02:21 - 04 Apr 2017 02:22 #90842 by cncnoob1979
Elroy,
Do you need 64 bit?
If not I would reinstall using a 32bit Linux mint Mate edition.
Seems you installed something different than what was required. Being new will be difficult to install 64bit stuff.
I assume you are at the stage of building 64bit LinuxCNC?
If you wish to continue 64bit then the dependencies you will need for gnomelibprintui are located on the first post. It's the official ubuntu mirror - kernel.org
You will have to enable this repository source to find the missing dependencies.
However with what you have shown I think a reinstall is in order. Less frustrating that way. But 32 bit is very easy to install.
Also the only really drawback to 32 bit is applications only able to access 4gb of memory. Which is plenty.
Edit: noticed you were not in the LinuxCNC-dev directory when you ran dpkg-checkbuilddeps
Try again please in the linuxcnc-dev directory.
Last edit: 04 Apr 2017 02:22 by cncnoob1979.
04 Apr 2017 02:39 #90844 by Elroy
I thought i had installed the 32 bit. How do i know what one i installed?
04 Apr 2017 02:44 #90845 by Elroy
I found my answer. I do have the 32bit.
elroy@elroy-Lenovo-V570 ~ $ cat /etc/lsb-release
DISTRIB_ID=LinuxMint
DISTRIB_RELEASE=18.1
DISTRIB_CODENAME=serena
DISTRIB_DESCRIPTION="Linux Mint 18.1 Serena"
elroy@elroy-Lenovo-V570 ~ $ uname -a
Linux elroy-Lenovo-V570 4.8.11-rt7 #1 SMP PREEMPT RT Sat Apr 1 15:20:50 CDT 2017 i686 i686 i686 GNU/Linux
  • cncnoob1979
  • Platinum Member
  • Platinum Member
04 Apr 2017 02:51 - 04 Apr 2017 02:54 #90846 by cncnoob1979
Edit: double post
Last edit: 04 Apr 2017 02:54 by cncnoob1979.
  • cncnoob1979
  • Platinum Member
  • Platinum Member
04 Apr 2017 02:53 #90847 by cncnoob1979
Yes that is 32bit.
Unmet build dependencies: libgnomeprintui2.2-dev python-support tcl8.4-dev tk8.4-dev
These are the dependencies that you need? That is typical for 64bit not 32bit.
I'll run a recompile in the morning to see what is going on. Perhaps something has changed?
Did you run a dist-upgrade or a apt-get update?
The 32bit dependencies have been available .. perhaps removed?
I'll get back with you tomorrow after work. I'll help you get going.
Is this a fresh install of mint?
  • cncnoob1979
  • Platinum Member
  • Platinum Member
04 Apr 2017 03:08 #90850 by cncnoob1979
Try this:
sudo apt-get install cdbs gnome-pkg-tools libxml2-dev libart-2.0-dev libglade2-dev libgnomecanvas2-dev libgnomeprint2.2-dev gtk-doc-tools intltool libglib2.0-doc libgtk2.0-doc
  • cncnoob1979
  • Platinum Member
  • Platinum Member
04 Apr 2017 03:12 #90851 by cncnoob1979
Are you building linuxcnc master or 2.7?
04 Apr 2017 03:22 #90852 by fjr122
I got my linuxcnc.deb file and got it installed.
Now I have other problems. :/
Anyways, Thanks Cncnoob for providing so much support to enable me to get here.
  • cncnoob1979
  • Platinum Member
  • Platinum Member
04 Apr 2017 11:12 #90859 by cncnoob1979
Great!
So what was your solution in the end?
Time to create page: 0.163 seconds
