LinuxCNC on Linux Mint 20 quick and nearly easy install
26 Oct 2020 13:23 #187305 by shortcircuit48
Replied by shortcircuit48 on topic LinuxCNC on Linux Mint 20 quick and nearly easy install
Thanks. I have tried that and every other combination of , recently used, all applications, accessories but nothing points to Linuxcnc. Only can load as previously described.
It is no big deal to wipe my drive and start afresh but just wonder why and if it will resolve.
26 Oct 2020 13:41 #187306 by Aciera
I have no idea as to why this happened but you can easily create your own starter icon on the desktop that executes a terminal command to start linuxcnc.
26 Oct 2020 13:58 #187309 by shortcircuit48
Thanks, I have found the application and launched with a desktop icon created, however no access to HAL etc
26 Oct 2020 14:17 #187311 by Aciera
You mean you can't find the INI and HAL files or the configuration folder?
26 Oct 2020 14:19 #187312 by shortcircuit48
Yes but very limited. Have wiped my drive and reinstalling, hopefully??
26 Oct 2020 14:32 - 26 Oct 2020 14:50 #187313 by shortcircuit48
Well the total reinstall of Mint has resolved the matter as the "CNC" menu has reappeared with all the options. A mystery why.
Last edit: 26 Oct 2020 14:50 by shortcircuit48.
18 Dec 2020 18:15 #192360 by Tetsuoi
It was nearly easy instal. Even as Im very much Linux newbie.
I made fresh instal from 2.8.0 Linuxcnc and Debian Wheezy.
Got linuxcnc running with my old Ini and Hal files, but now I have these problems.
- when starting Linuxcnc: hm2/hm2_5i25.0: Smart serial port 0: Dolt not cleared from previous servo thread.servo thread propably too fast.
File Name: optimumjyrsin.hal
File Size:9 KB
File Name: optimumjyrsin.ini
File Size:4 KB
- also my servos are making sounds, like belts would be cracking. Hal file has previous PID tuning adjustments done, even though I went to pnconfig and loose all my settings. i know, custom.hal next time. This is my main problem.
- on pnconfig comes error about missing hosmot2
Wanted to make this update, becouse I have been fighting with Vistacnc pendant for days, its disconnecting usb Very often. This is still to be tested.
  • tommylight's Avatar Topic Author
  • Moderator
  • Moderator
18 Dec 2020 18:39 #192361 by tommylight
What does
uname -a
in a terminal say ?
18 Dec 2020 18:53 #192363 by Tetsuoi
linux teppo 5.4.0-26-generic #30-ubuntu SMP mon apr 20 16:58:30 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
18 Dec 2020 19:25 #192367 by PCW
Looks like you did not install a real time kernel.
Time to create page: 4.287 seconds
