LinuxCNC on Linux Mint 20 quick and nearly easy install
- BigJohnT
- Thank you received: 994
18 Feb 2021 00:16 #199209
by BigJohnT
Replied by BigJohnT on topic LinuxCNC on Linux Mint 20 quick and nearly easy install
tommylight, do you know if a internet connection is required to install? I tried this morning with a USB adapter micro SD card and it said it failed to read the CD drive? I had no internet this morning as the dish was covered with snow...
JT
JT
- Thank you received: 7478
18 Feb 2021 00:35 #199213
Replied by tommylight on topic LinuxCNC on Linux Mint 20 quick and nearly easy install
To install Linux Mint it does not, just do not choose to update while installing or to install additional codex.
Most of the other files can be downloaded and transferred, but i am sure there are some other files downloaded during install that are not on the list.
- MarcoGaspar
21 Feb 2021 18:38 #199640
by MarcoGaspar
Replied by MarcoGaspar on topic LinuxCNC on Linux Mint 20 quick and nearly easy install
Hello,
Thanks for the 5* post
I installed mint 20 following this post steps and it's all working (linuxcnc).
The only thing i can't do is setting a higher resolution for my monitor on RT kernel how can i add more resolutions?
Best Regards,
Marco Gaspar
Best Regards,
Marco Gaspar
21 Feb 2021 21:05 #199648
What does
xrandr
in a terminal say ?
xrandr
in a terminal say ?
- MarcoGaspar
21 Feb 2021 21:27 - 21 Feb 2021 21:43 #199651
by MarcoGaspar
xrandr
xrandr: Failed to get size of gamma for output default
Screen 0: minimum 640 x 480, current 640 x 480, maximum 640 x 480
default connected primary 640x480+0+0 0mm x 0mm
640x480 73.00*
cvt 1920 1080 60
# 1920x1080 59.96 Hz (CVT 2.07M9) hsync: 67.16 kHz; pclk: 173.00 MHz
Modeline "1920x1080_60.00" 173.00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsync
xrandr --addmode default 1920x1080_60.00
xrandr: cannot find mode "1920x1080_60.00"
640x480 73.00*
cvt 1920 1080 60
Last edit: 21 Feb 2021 21:43 by MarcoGaspar. Reason: Adding
21 Feb 2021 22:25 #199658
Something very screwy there, no graphic anything!
What graphic card?
Here is what i get:
What graphic card?
Here is what i get:
cnc@X570:~$ xrandr
Screen 0: minimum 320 x 200, current 2560 x 1440, maximum 16384 x 16384
DisplayPort-0 disconnected primary (normal left inverted right x axis y axis)
DisplayPort-1 disconnected (normal left inverted right x axis y axis)
HDMI-A-0 connected 2560x1440+0+0 (normal left inverted right x axis y axis) 708mm x 399mm
2560x1440 59.95*+ 69.93
1920x1200 59.95
1920x1080 60.00 50.00 59.94
1600x1200 60.00
1680x1050 59.88
1600x900 60.00
1280x1024 60.02
1440x900 59.90
1280x800 59.95
1280x720 60.00 50.00 59.94
1024x768 60.00
800x600 60.32
720x576 50.00
720x480 60.00 59.94
640x480 60.00 59.94
720x400 70.08
HDMI-A-1 disconnected (normal left inverted right x axis y axis)
DVI-D-0 disconnected (normal left inverted right x axis y axis)
cnc@X570:~$ Please Log in or Create an account to join the conversation.
- MarcoGaspar
21 Feb 2021 22:32 #199661
by MarcoGaspar
22 Feb 2021 01:22 #199668
In general, if something is not working on Linux Mint i blame the hardware !
Can you try to boot with the generic kernel and check if that works?
I am aware that RTAI kernel caused low resolution on some PC's but it was at least 1024x768, never had issues with RT-Preempt on any PC, and i have 3 of them and 3 laptops on this desk only, more in the shop.
- MarcoGaspar
22 Feb 2021 06:39 #199679
by MarcoGaspar
I will reinstall it.
Maybe a graphic card solve this?
- MarcoGaspar
22 Feb 2021 20:52 #199765
by MarcoGaspar
Its the same.... already try to reinstall 3 or 4 times...
without the rt it works:
mjg@CNC:~$ xrandr
Screen 0: minimum 320 x 200, current 1024 x 768, maximum 16384 x 16384
DP-1 connected primary 1024x768+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
1024x768 60.00*
800x600 60.32 56.25
848x480 60.00
640x480 59.94
HDMI-1 disconnected (normal left inverted right x axis y axis)
mjg@CNC:~$
mjg@CNC:~$ xrandr
1024x768 60.00*
800x600 60.32 56.25
848x480 60.00
640x480 59.94
mjg@CNC:~$
Time to create page: 1.448 seconds
