Installing LCNC on Beelink BT3 PRO II
- htdave
5 years 4 months ago #211109
by htdave
Replied by htdave on topic Installing LCNC on Beelink BT3 PRO II
I have just finished installing mint 19 xfce, using the step by step from Tommylight.
When I boot with RT, the system lacks stability.
When I type lspci -vn, I get:
Still no wifi
Any ideas?
lagunmatic@lagunmatic:~$ lspci -vn
00:00.0 0600: 8086:2280 (rev 36)
Subsystem: 8086:7270
Flags: bus master, fast devsel, latency 0
Kernel driver in use: iosf_mbi_pci
00:02.0 0300: 8086:22b0 (rev 36) (prog-if 00 [VGA controller])
Flags: bus master, fast devsel, latency 0, IRQ 300
Memory at 90000000 (64-bit, non-prefetchable) [size=16M]
Memory at 80000000 (64-bit, prefetchable) [size=256M]
I/O ports at f000 [size=64]
[virtual] Expansion ROM at 000c0000 [disabled] [size=128K]
Capabilities: <access denied>
Kernel driver in use: i915
Kernel modules: i915
00:03.0 0480: 8086:22b8 (rev 36)
Flags: fast devsel, IRQ 255
Memory at 91000000 (32-bit, non-prefetchable) [disabled] [size=4M]
00:0b.0 1180: 8086:22dc (rev 36)
Flags: fast devsel, IRQ 301
Memory at 9193b000 (64-bit, non-prefetchable) [size=4K]
Kernel driver in use: proc_thermal
Kernel modules: processor_thermal_device
00:14.0 0c03: 8086:22b5 (rev 36) (prog-if 30 [XHCI])
Flags: bus master, medium devsel, latency 0, IRQ 299
Memory at 91900000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
00:1a.0 1080: 8086:2298 (rev 36)
Flags: bus master, fast devsel, latency 0, IRQ 255
Memory at 91700000 (32-bit, non-prefetchable) [size=1M]
Memory at 91600000 (32-bit, non-prefetchable) [size=1M]
00:1c.0 0604: 8086:22c8 (rev 36) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 297
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000e000-0000efff
Memory behind bridge: 91800000-918fffff
Kernel driver in use: pcieport
Kernel modules: shpchp
00:1f.0 0601: 8086:229c (rev 36)
Kernel driver in use: lpc_ich
Kernel modules: lpc_ich
01:00.0 0200: 10ec:8168 (rev 0c)
Subsystem: 10ec:0123
Flags: bus master, fast devsel, latency 0, IRQ 298
I/O ports at e000 [size=256]
Memory at 91804000 (64-bit, non-prefetchable) [size=4K]
Memory at 91800000 (64-bit, prefetchable) [size=16K]
Kernel driver in use: r8169
Kernel modules: r8169
Still no wifi
Any ideas?
- BeagleBrainz
- Visitor
5 years 4 months ago - 5 years 4 months ago #211120
by BeagleBrainz
Replied by BeagleBrainz on topic Installing LCNC on Beelink BT3 PRO II
If you still have the Mint 19 installed could you try
I may not have made myself clear.
Boot into a live session of Mint 20 then run
and could you also try
and attached both text files.
I suggest this as due to your claim that Mint 20 gets you wifi.
The output of dmesg will also be useful.
When you say the system lacks stability what do you mean. What issues are presenting.
This is a link to the Mint 19 iso I created.
drive.google.com/file/d/1d7IEscVlyWoNZQe...s4D/view?usp=sharing
If you would like to test this for stability you are welcome to. Some of the repos no longer exist, but that is not the point. The point is to test if the kernel on this ISO will give you better/any stability. This will give you a full installation of Mint 19 with a PREEMPT kernel & linuxcnc.
Just had a look at the iso, the firmware is there for the wifi chip, all that is missing is the nvram text file.
If it is stable and you want to run with it we can sort the repos out as it is quite simple.
Or send the thing down to Sydney and I'll get it going by hell or high water :lol:
Oh ok this seems to be the same CPU that was used on the Atomic Pi, not exactly the fastest one out there. Even when I tried it with LXDE it wasn't the greatest
Sorry if this post is a bit all over the place, but I'm willing to answer any questions you have.
dmesg | grep brcm > brcm.txt
lspci -vn > lspci.txt
Last edit: 5 years 4 months ago by BeagleBrainz.
- Thank you received: 7491
5 years 4 months ago #211144
Replied by tommylight on topic Installing LCNC on Beelink BT3 PRO II
The thing with WiFi is, even if you make it work with the RT kernel it might mess up latency badly, so might need to disable it and use a WiFi dongle.
- BeagleBrainz
- Visitor
5 years 4 months ago #211146
by BeagleBrainz
Yeah that's a good point and what I was thinking regarding getting a dongle.
I just had a look in the /lib/firmware/brcm dir of Mint 19 & Mint 20 whilst Mint 19 has the bin files the txt files are missing.
Maybe copying the Mint 20 txt files to Mint 19 would get it working.
The wifi should work as it's the same that the RPi4 uses.
- BeagleBrainz
- Visitor
5 years 4 months ago #211154
by BeagleBrainz
- htdave
5 years 4 months ago #211286
by htdave
I ended up installing 19.3 from an iso I had for my odroid - pretty sure it was from beaglebrainz.
It all runs fine except no WiFi. Perhaps I should just get a usb wifi - any suggestions on a decent one?
Jitter is not good - about 250,000 max. Is this way too high even for a mesa? Anything I should be doing to reduce jitter?
Is it worth persevering with this pc, or should i get something better? It is for a VMC that will be used in our manufacturing business, so needs to be reliable.
Time to create page: 0.161 seconds
