- Thank you received: 4153
Installing LCNC on Beelink BT3 PRO II
5 years 4 months ago #211074
I think Mint 19.3 is a better option. That is what Tommy linked to. I followed his 19.3 instructions the other day and it worked perfect!
I have wifi!
Replied by rodw on topic Installing LCNC on Beelink BT3 PRO II
htdave wrote: Wifi worked on Mint 20, until I installed the RT kernel, then no Wifi
I have wifi!
- htdave
5 years 4 months ago #211080
by htdave
I'll give that a go then.
Replied by htdave on topic Installing LCNC on Beelink BT3 PRO II
I have wifi!
- BeagleBrainz
- Visitor
5 years 4 months ago #211082
by BeagleBrainz
Replied by BeagleBrainz on topic Installing LCNC on Beelink BT3 PRO II
I'd go with a USB wifi dongle and be done with it.
Another thing you can do is run a live session of Mint 20 and go through dmesg to see what gets loaded.
Look it just may be that that particular wifi device is not supported by a 4.19 kernel, it may need a later kernel.
The PCI id of the device is a good place to start:
lspci -vn
- Goulven
- Thank you received: 3
5 years 4 months ago #211085
by Goulven
Replied by Goulven on topic Installing LCNC on Beelink BT3 PRO II
If you want to use the standart installation, i found this post on ubuntu forum. The nvram.txt file is still online here:
github.com/khadas/android_hardware_amlog...cm_ampak/config/6255
Cf:
forum.ubuntu-fr.org/viewtopic.php?id=2033578
#14
Cf:
#14
wget https://github.com/khadas/android_hardware_amlogic_wifi/raw/b6709758755568e4a0ff6e80993be0fc64c77fb9/bcm_ampak/config/6255/nvram.txt
sudo cp nvram.txt /lib/firmware/brcm/brcmfmac43455-sdio.txt
- htdave
5 years 4 months ago #211086
by htdave
Would you go Mate or XFCE?
- BeagleBrainz
- Visitor
5 years 4 months ago #211089
by BeagleBrainz
XFCE is lighter on resources.
Time to create page: 0.975 seconds
