Installing LCNC on Beelink  BT3 PRO II
5 years 4 months ago #211287 by Clive S
Replied by Clive S on topic Installing LCNC on Beelink  BT3 PRO II
No eBay APP ID and/or Cert ID defined in Kunena configuration
It all runs fine except no WiFi. Perhaps I should just get a usb wifi - any suggestions on a decent one?
I have bought several of these without any issues. I see they have gone up in price lately
  • BeagleBrainz
  • Visitor
  • Visitor
5 years 4 months ago #211297 by BeagleBrainz
Replied by BeagleBrainz on topic Installing LCNC on Beelink  BT3 PRO II
htdave wrote: I ended up installing 19.3 from an iso I had for my odroid - pretty sure it was from beaglebrainz.
Jitter is not good - about 250,000 max. Is this way too high even for a mesa? Anything I should be doing to reduce jitter?
Is it worth persevering with this pc, or should i get something better? It is for a VMC that will be used in our manufacturing business, so needs to be reliable.
Follow the link in this post to grab the nvram file.
forum.linuxcnc.org/9-installing-linuxcnc...o-ii?start=10#211154
Like I said Mint 19 has the firmware all that is missing is the text file.
The efivars filesystem should already be mounted.
For the jitter just the usual,
Turn off any power saving and you may also use the isolcpu kernel commandline option.
Mint works with just about any USB wifi dongle.
5 years 4 months ago #211392 by htdave
Replied by htdave on topic Installing LCNC on Beelink  BT3 PRO II
Is there a guide to using isolcpu? I'm a complete newbie to linux
What is an acceptable max jitter for Mesa Ethernet?
Will work through the wifi over the next few weeks as time permits.
Thanks again for all the help
  • BeagleBrainz
  • Visitor
  • Visitor
5 years 4 months ago #211395 by BeagleBrainz
The search function should turn up numerous hits for isolcpu or it maybe isolcpus.
If you weren’t so north of my location I’d offer my time for nix to help ya out.
5 years 4 months ago #211397 by htdave
Maybe I'm better off sending it down to you and getting you to set it all up correctly - I'm happy to pay for your time
  • Moderator
  • Moderator
5 years 4 months ago #211398 by tommylight
Replied by tommylight on topic Installing LCNC on Beelink  BT3 PRO II
htdave wrote: What is an acceptable max jitter for Mesa Ethernet?
126uS for sure is OK (126000 nS), as i have an old laptop that does that and works for days without dropping the link.
Time to create page: 1.300 seconds
