Installing LCNC on Beelink  BT3 PRO II
  • BeagleBrainz
  • Visitor
  • Visitor
5 years 4 months ago - 5 years 4 months ago #211795 by BeagleBrainz
Replied by BeagleBrainz on topic Installing LCNC on Beelink  BT3 PRO II
Is that with a standard kernel, debian rt or my rt kernel.
hmmm maybe I changed the dmesg permission
rmurphy@thinkPad-t530:~$ ls -la /bin/dmesg -rwxr-xr-x 1 root root 72000 Sep 17 2020 /bin/dmesg
But this means I must have done it on ALL Mint installations on ALL machines, even those that have multiple versions of Mint.
Ok it's not that, I deleted /bin/dmesg then reinstalled util-linux (package for dmesg) & permissions were the same.
OK Dave you may have to run the dmesg command with sudo in front of it.
Hey Tommy just for interest can you run:
cat /proc/sys/kernel/dmesg_restrict
If you get something other than 0 can you try,
sudo sysctl -w kernel.dmesg_restrict=0
Then try dmesg without sudo
To go back to previous, ie sudo requires dmesg
sysctl -w kernel.dmesg_restrict=1
OK found out that there is a kernel config option that changes the operation of dmesg, to do with wether a user can read log.
The kernel I built, taken the default config from a std Mint kernel, allows a normal user to use dmesg without using sudo, the debian RT kernel does not allow this behaviour.
Last edit: 5 years 4 months ago by BeagleBrainz.
  • Moderator
  • Moderator
5 years 4 months ago #211820 by tommylight
Replied by tommylight on topic Installing LCNC on Beelink  BT3 PRO II
The following user(s) said Thank You: BeagleBrainz
  • Moderator
  • Moderator
5 years 4 months ago #211830 by tommylight
Some info on the picture above, there are all the lines run and the version of kernel, all this is on Linux Mint 19.3 with all the latest updates, and sure enough the kernel is from the Debian Stretch repository.
As can be seen above, the line proposed by Beagle does it's magic and now dmesg works with no sudo privileges.
Thank you Beagle.
  • BeagleBrainz
  • Visitor
  • Visitor
5 years 4 months ago #211832 by BeagleBrainz
Not too sure if that with survive a reboot.
Although we haven’t sorted dave’s Issue we’ve learnt something.
Sorry about going off topic.
  • Moderator
  • Moderator
5 years 4 months ago #211834 by tommylight
BeagleBrainz wrote: Not too sure if that with survive a reboot.
It did not.
5 years 4 months ago #212062 by htdave
Replied by htdave on topic Installing LCNC on Beelink  BT3 PRO II
Hi Guys,
I'm pretty flat out at the moment, so haven't had a chance to check. will hopefully get there later in the week.
Time to create page: 1.531 seconds
