Installing LCNC on Beelink  BT3 PRO II
  • BeagleBrainz
  • Visitor
  • Visitor
5 years 4 months ago #211415 by BeagleBrainz
Replied by BeagleBrainz on topic Installing LCNC on Beelink  BT3 PRO II
htdave wrote:
If you weren’t so north of my location I’d offer my time for nix to help ya out.
Maybe I'm better off sending it down to you and getting you to set it all up correctly - I'm happy to pay for your time
Don't worry about paying for my time, I've got plenty of that at the moment.
I'll give you my postcode, 2168, just so you can get a quote for postage there and back and we'll go from there.
5 years 4 months ago #211482 by htdave
Replied by htdave on topic Installing LCNC on Beelink  BT3 PRO II
Thanks for that. I've just ordered a usb wifi, so once that turns up, I'll see how everything is going, and if I am still having no luck, I'll ship it down to you.
Thanks again for all the help :)
  • BeagleBrainz
  • Visitor
  • Visitor
5 years 4 months ago - 5 years 4 months ago #211486 by BeagleBrainz
Could you just try something ?
tar -cvzf efivars.tar.gz /sys/firmware/efi/efivars/
dmesg | grep bcrm > dmesg.txt
And post both files.
Last edit: 5 years 4 months ago by BeagleBrainz.
5 years 4 months ago #211669 by htdave
~$ tar -cvzf efivars.tar.gz /sys/firmware/efi/efivars/ tar: Removing leading `/' from member names /sys/firmware/efi/efivars/ /sys/firmware/efi/efivars/MokListRT-605dab50-e046-4300-abb6-3dd810dd8b23 /sys/firmware/efi/efivars/BootCurrent-8be4df61-93ca-11d2-aa0d-00e098032b8c /sys/firmware/efi/efivars/PlatformLangCodes-8be4df61-93ca-11d2-aa0d-00e098032b8c /sys/firmware/efi/efivars/ErrOutDev-8be4df61-93ca-11d2-aa0d-00e098032b8c /sys/firmware/efi/efivars/BootOptionSupport-8be4df61-93ca-11d2-aa0d-00e098032b8c /sys/firmware/efi/efivars/ConInDev-8be4df61-93ca-11d2-aa0d-00e098032b8c /sys/firmware/efi/efivars/ConOutDev-8be4df61-93ca-11d2-aa0d-00e098032b8c /sys/firmware/efi/efivars/OsIndicationsSupported-8be4df61-93ca-11d2-aa0d-00e098032b8c /sys/firmware/efi/efivars/OA3MSDMvariable-01368881-c4ad-4b1d-b631-d57a8ec8db6b /sys/firmware/efi/efivars/FPDT_Volatile-01368881-c4ad-4b1d-b631-d57a8ec8db6b /sys/firmware/efi/efivars/PKDefault-8be4df61-93ca-11d2-aa0d-00e098032b8c /sys/firmware/efi/efivars/KEKDefault-8be4df61-93ca-11d2-aa0d-00e098032b8c /sys/firmware/efi/efivars/dbDefault-8be4df61-93ca-11d2-aa0d-00e098032b8c /sys/firmware/efi/efivars/dbxDefault-8be4df61-93ca-11d2-aa0d-00e098032b8c /sys/firmware/efi/efivars/PlatformInfo-10ba6bbe-a97e-41c3-9a07-607ad9bd60e5 /sys/firmware/efi/efivars/S3SS-4bafc2b4-02dc-4104-b236-d6f1b98d9e84 /sys/firmware/efi/efivars/VendorKeys-8be4df61-93ca-11d2-aa0d-00e098032b8c /sys/firmware/efi/efivars/SecureBoot-8be4df61-93ca-11d2-aa0d-00e098032b8c /sys/firmware/efi/efivars/SetupMode-8be4df61-93ca-11d2-aa0d-00e098032b8c /sys/firmware/efi/efivars/SignatureSupport-8be4df61-93ca-11d2-aa0d-00e098032b8c /sys/firmware/efi/efivars/Boot0006-8be4df61-93ca-11d2-aa0d-00e098032b8c /sys/firmware/efi/efivars/Boot0005-8be4df61-93ca-11d2-aa0d-00e098032b8c /sys/firmware/efi/efivars/BootOrder-8be4df61-93ca-11d2-aa0d-00e098032b8c /sys/firmware/efi/efivars/Boot0000-8be4df61-93ca-11d2-aa0d-00e098032b8c /sys/firmware/efi/efivars/MemoryOverwriteRequestControl-e20939be-32d4-41be-a150-897f85d49829 /sys/firmware/efi/efivars/SetUpdateCountVar-81c76078-bfde-4368-9790-570914c01a65 /sys/firmware/efi/efivars/Timeout-8be4df61-93ca-11d2-aa0d-00e098032b8c /sys/firmware/efi/efivars/PlatformLang-8be4df61-93ca-11d2-aa0d-00e098032b8c /sys/firmware/efi/efivars/dbx-d719b2cb-3d3a-4596-a3bc-dad00e67656f /sys/firmware/efi/efivars/ErrOut-8be4df61-93ca-11d2-aa0d-00e098032b8c /sys/firmware/efi/efivars/ConOut-8be4df61-93ca-11d2-aa0d-00e098032b8c /sys/firmware/efi/efivars/Boot0004-8be4df61-93ca-11d2-aa0d-00e098032b8c /sys/firmware/efi/efivars/OfflineUniqueIDEKPubCRC-eaec226f-c9a3-477a-a826-ddc716cdc0e3 /sys/firmware/efi/efivars/OfflineUniqueIDEKPub-eaec226f-c9a3-477a-a826-ddc716cdc0e3 /sys/firmware/efi/efivars/OfflineMemoryDumpUseCapability-77fa9abd-0359-4d32-bd60-28f4e78f784b /sys/firmware/efi/efivars/UnlockIDCopy-eaec226f-c9a3-477a-a826-ddc716cdc0e3 /sys/firmware/efi/efivars/CurrentPolicy-77fa9abd-0359-4d32-bd60-28f4e78f784b /sys/firmware/efi/efivars/MaximumTableSize-4b3082a3-80c6-4d7e-9cd0-583917265df1 /sys/firmware/efi/efivars/SmbiosScratchBuffer-4b3082a3-80c6-4d7e-9cd0-583917265df1 /sys/firmware/efi/efivars/SmbiosV3EntryPointTable-4b3082a3-80c6-4d7e-9cd0-583917265df1 /sys/firmware/efi/efivars/SmbiosEntryPointTable-4b3082a3-80c6-4d7e-9cd0-583917265df1 /sys/firmware/efi/efivars/TrEEPhysicalPresence-f24643c2-c622-494e-8a0d-4632579c2d5b /sys/firmware/efi/efivars/Boot0003-8be4df61-93ca-11d2-aa0d-00e098032b8c /sys/firmware/efi/efivars/ConIn-8be4df61-93ca-11d2-aa0d-00e098032b8c /sys/firmware/efi/efivars/WriteOnceStatus-4b3082a3-80c6-4d7e-9cd0-583917265df1 /sys/firmware/efi/efivars/EfiTime-9d0da369-540b-46f8-85a0-2b5f2c301e15 /sys/firmware/efi/efivars/MemCeil.-01368881-c4ad-4b1d-b631-d57a8ec8db6b /sys/firmware/efi/efivars/nvram-74b00bd9-805a-4d61-b51f-43268123d113 /sys/firmware/efi/efivars/MonotonicCounter-01368881-c4ad-4b1d-b631-d57a8ec8db6b
dmesg | grep bcrm > dmesg.txt Does nothing
I have just plugged in a usb wifi (I believe Realtek) and still nothing
  • BeagleBrainz
  • Visitor
  • Visitor
5 years 4 months ago - 5 years 4 months ago #211674 by BeagleBrainz
dmesg | grep bcm > dmesg.txt
Creates a text file with the output of the command, instead of sending it to the screen, known as redirection.
[hr]
Creates a compressed named efivars.tar.gz with all the contents of /sys/firmware/efi/efivars
[hr]
I meant can you attach the tar.gz (you will need to change to name to efivars.tar.gz ) & txt files as an attachment. So I can download them and do some magic to hopefully get the on board wifi up.
What does dmesg output before & after plugging in the usb device ?
Run this so you have lsusb
sudo apt-get install usbutils
Then run
lsusb
5 years 4 months ago #211749 by htdave
With USB Wifi plugged in:
lsusb Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 005: ID 0bda:f179 Realtek Semiconductor Corp. Bus 001 Device 004: ID 2575:0401 Bus 001 Device 003: ID 093a:2510 Pixart Imaging, Inc. Optical Mouse Bus 001 Device 002: ID 0b38:0010 Gear Head 107-Key Keyboard Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Without:
$ lsusb Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 004: ID 2575:0401 Bus 001 Device 003: ID 093a:2510 Pixart Imaging, Inc. Optical Mouse Bus 001 Device 002: ID 0b38:0010 Gear Head 107-Key Keyboard Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
File Name: dmesg.txt
File Size:0 KB
File Name: efivars.tar.gz
File Size:11 KB
txt file appears to be empty
It appears that the realtek is being recognised. apart from that, it is beyond my comprehension
Time to create page: 0.898 seconds
