RPI4 - Debian / LinuxCNC / EtherCAT / XFCE
4 years 5 months ago #243299 by rodw
The wheel is in
build/dist
on my pi it is called
vtk-9.1.20220518.dev0-cp310-cp310-linux_aarch64.whl
So tonight I'll be onto installing qtpyvcp
The following user(s) said Thank You: elovalvo
4 years 5 months ago - 4 years 5 months ago #243304 by elovalvo
The wheel is in
build/dist
vtk-9.1.20220518.dev0-cp310-cp310-linux_aarch64.whl So tonight I'll be onto installing qtpyvcp
To install qtvcp you need these commands:
sudo apt-get install python3-gst-1.0 cd /usr/lib/python3/dist-packages/qtvcp/designer sed 's/x86_64/aarch64/g' ./install_script > /tmp/install_64_script sudo cp /tmp/install_64_script . sudo chmod a+x ./install_64_script ./install_64_script
and than
select 3 = Yes, for a package installation
Last edit: 4 years 5 months ago by elovalvo.
4 years 5 months ago #243333 by rodw
elovalvo's method to install qtvcp did not work for me, At least the install script ran perfectly instead of erroring. I was getting segmentation faults with qtplasmac, and other sample screens did not load.
but adding
processor.max_cstate=1
to cmdline.txt made a substantial improvement on latency
10 glx gears vs 6 previously. I'll let it run overnight again.
I just have to try  qtpyvcp but that will be another night.
I did grab a 64 bit SD card today so its time to try rebuilding the image tomorrow.
We had incessant internet outages today so could not get any work done, let alone playing with this..
4 years 5 months ago - 4 years 5 months ago #243346 by ftree
Excellent, will add to the boot cmd too!
I now have LXQT v1.1 installed as default. Will commit that soon.
I have forked forked FalconView with a view to make it look inkeeping with an modern LXQT based ui.
Busy getting the robot working on EtherCAT....
Last edit: 4 years 5 months ago by ftree.
4 years 5 months ago #243356 by rodw
Well, overnight the latency is a bit worse but the shape is much narrower
4 years 5 months ago #243357 by rodw
hmm, clicking on a png image (screenshot)  would not open it.
sudo apt install feh
fixed that
Just experiment with cstates before adding to your image. I just realised the horizontal scale was different between my overnight runs so it might be worse..
Time to create page: 0.273 seconds
