RPI4 - Debian / LinuxCNC / EtherCAT / XFCE
3 years 10 months ago #259192 by hamed
   hello
   i use your code for installing on rpi
   but i have an error after running this command:
sudo make image board=bcm2711
    the error is this:
Setting up python3-matplotlib (3.5.2-4) ...
Processing triggers for libglib2.0-0:arm64 (2.74.2-1) ...
Processing triggers for libc-bin (2.36-6) ...
Processing triggers for man-db (2.11.1-1) ...
/usr/bin/mandb: can't write to /var/cache/man/82238: No space left on device
/usr/bin/mandb: can't create index cache /var/cache/man/82238: No space left on devic        e
Setting up glib-networking:arm64 (2.74.0-1) ...
Processing triggers for fontconfig (2.13.1-4.5) ...
Setting up libsoup2.4-1:arm64 (2.74.3-1) ...
Setting up gstreamer1.0-plugins-good:arm64 (1.20.3-1+b1) ...
Setting up libsoup-3.0-0:arm64 (3.2.2-1) ...
Setting up libgssdp-1.6-0:arm64 (1.6.2-2) ...
Setting up libgupnp-1.6-0:arm64 (1.6.2-1) ...
Setting up libgupnp-igd-1.0-4:arm64 (1.2.0-3) ...
Setting up libnice10:arm64 (0.1.18-2) ...
Setting up gstreamer1.0-plugins-bad:arm64 (1.20.3-2+b1) ...
+ python3 -m pip install /root/userscripts/vtk-9.1.20220601.dev0-cp310-cp310-linux_aa        rch64.whl
Processing /root/userscripts/vtk-9.1.20220601.dev0-cp310-cp310-linux_aarch64.whl
Installing collected packages: vtk
ERROR: Could not install packages due to an OSError: [Errno 28] No space left on device
make: *** [Makefile:132: image] Error 1
  i have enough space on sd card (64GB)
   but i think your volume that  specified for installing vtk is not enough
  my report of sd card is:
hamed@raspberrypi:~/Downloads/rpi-img-builder-master $  df -Bm
Filesystem     1M-blocks   Used Available Use% Mounted on
/dev/root         59626M 18837M    38311M  33% /
devtmpfs           3745M     0M     3745M   0% /dev
tmpfs              3907M     0M     3907M   0% /dev/shm
tmpfs              1563M     2M     1562M   1% /run
tmpfs                 5M     1M        5M   1% /run/lock
/dev/mmcblk0p1      255M    72M      184M  29% /boot
tmpfs               782M     1M      782M   1% /run/user/1000
/dev/loop1p1       4610M     1M     4356M   1% /home/hamed/Downloads/rpi-img-builder-master/sysroot
/dev/loop2p1        256M    56M      201M  22% /home/hamed/Downloads/rpi-img-builder-master/p1
/dev/loop2p2       7161M  7142M        0M 100% /home/hamed/Downloads/rpi-img-builder-master/p2
at first thanks for your great job
but if you have any point for solving my problem, please help me.
Time to create page: 0.258 seconds
