RPI4 - Debian / LinuxCNC / EtherCAT / XFCE
4 years 5 months ago - 4 years 5 months ago #243078 by ftree
Thanks, updated title and ammended first post.
Still having issues setting up the correct key store for the etherlab repo.
The key appears to be for Release and not InRelease.
Last edit: 4 years 5 months ago by ftree.
4 years 5 months ago #243082 by ftree
Until I can figure out how to import the right keys from EtherLab repo
github.com/djsftree/rpi-img-builder/comm...ed32642c661b2b26291b
echo "deb [allow-insecure=yes] https://download.opensuse.org/repositories/home:/bone11111:/branches:/science:/EtherLab/Debian_11/ ./" >> /etc/apt/sources.list apt update --allow-unauthenticated apt install -y --allow-unauthenticated ethercat-dkms libethercat libethercat-dev ethercat-master
4 years 5 months ago - 4 years 5 months ago #243083 by ftree
5.15.36-rt41 now installs and rebuilds the ethercat modules.  Result!
4 years 5 months ago #243084 by ftree
Tested - boots to login ok!
4 years 5 months ago #243093 by rodw
Sweet! I woke up early (4;30am here) and went back to the Debian repo notes
build.opensuse.org/project/show/home:bon...hes:science:EtherLab
and had just worked out to change to Debian_11 for bullseye
Bookworm would need to use Debian_Testing
When you say boots to login, is that a terminal login or a GUI login?
If you end up with a terminal login, tasksel will install a GUI of your choice on the pi.
4 years 5 months ago - 4 years 5 months ago #243095 by ftree
lightdm login, now with onscreen login keyboard. Just commited that. I was looking at customising the login with a LinuxCNC wallpaper. :-)
Etherlab Debian_11 seems to work ok as a bookworm kernel module - so far.
lines 16/17
github.com/djsftree/rpi-img-builder/blob/master/userdata.txt
16 Distro : debian
17 Release: bullseye, bookworm, testing, unstable and sid
Many options for resulting image!
Time to create page: 0.288 seconds
