LinuxCNC on Raspberry Pi 5
2 years 3 months ago #304497 by swepeter
Replied by swepeter on topic LinuxCNC on Raspberry Pi 5
First of all thanks for the great work.
is it just me or is the link on the website wrong?
www.linuxcnc.org/iso/rpi-5-debian-bookwo...23-11-17-1520.img.xz
it say: LinuxCNC 2.9.2
but when I start it it say 2.9.1
I thought I had an older one so I reinstalled today and still the same.
Can I upgrade linuxCNC and GMOCCAPY?
i had some issues with GMOCCAPY now compared to when I was running the PI4 that I installed years ago.
One issue I had was when I pressed the aport button during a probing script, it did not stop but the GUI changed.
I will try to reproduce.
I copied my old config. Can that be the issue? I thought you could
github.com/swepeter/PrintNC
Thanks all
2 years 3 months ago #305946 by timaer
Replied by timaer on topic LinuxCNC on Raspberry Pi 5
Hey,elovalvo,I've installed your image in my rasppi5 machine,but met a problem while I installed the linuxcnc-ethercat ,I cant run "sudo apt install -y linux-headers-$(uname -r) ethercat-master linuxcnc-ethercat",because I cant find the right kernel version of header,could you offered that ? Thank you
2 years 3 months ago #306099 by elovalvo
Replied by elovalvo on topic LinuxCNC on Raspberry Pi 5
if you are using the image from this link
forum.linuxcnc.org/9-installing-linuxcnc...pi-5?start=40#303752
maybe they should already be installed.
I've never used Ethercat so I've never had this problem.
However you can see at this link
linuxconfig.org/how-to-install-linux-ker...ders-on-raspberry-pi
The following user(s) said Thank You: timaer
2 years 3 months ago #306144 by timaer
Thank you so much ,that's very helpful.
  • Krister
  • New Member
  • New Member
2 years 2 weeks ago #312410 by Krister
Replied by Krister on topic LinuxCNC on Raspberry Pi 5
Hi One problem solved and one remain ,I replaced the analog optical sensor to a "digital" one and the revolution meter start to work . the reading is ok and the reading is controled with a speedometer. the other problem is the red and green LED weryfing to start the process from the G-code program  G97 S600 M3 The program start at 150 rpm and the red LED starts at 350 rev, it is mirror action , it should start at ca 450 and stopp at ca 700 revs ,it is programd with 150 % tolerans .
1 year 11 months ago #315090 by msurmei
Replied by msurmei on topic LinuxCNC on Raspberry Pi 5
Maybe it's useful info ...
i had to power the RPI5 using a normal 5V/10A DIN power supply. Manage to do it and keep 4.7V at 3.1 A , enough for RPI to avoid detection of an undervoltage condition.
But then I was curios about the official RPI power supply ... and I have tested it with an electronic load: I've got the same voltage ( around 5.14V) from 0.5A up to 5.9 A .. at 6A it shuts itself down nice and safely ).
I think the official power supply is dinamically compensating the cable impedance by increasing the output voltage from the regulator based on measured current .
So if you need 5A , be very careful with the cable or just use the official power  supply , if possible ...
All of these where done with PD disabled ( a small USB-C breakout board with 5.11kohm on CC lines)
Time to create page: 0.317 seconds
