LinuxCNC on Raspberry Pi 5
07 Dec 2023 19:50 #287477 by flyingbrick
Replied by flyingbrick on topic LinuxCNC on Raspberry Pi 5
Hi Cornholio, Stupid question- Lack of I/O support wont affect the 5's ability to run an ethernet card? (I have one on the way, still trying to decide what machine i want to use to drive it) Just my luck that there would be some weird conflict that means its a no-go.
  • Platinum Member
  • Platinum Member
07 Dec 2023 20:24 #287481 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic LinuxCNC on Raspberry Pi 5
Should be ok.
Haven’t tested it myself.
07 Dec 2023 21:28 - 07 Dec 2023 22:23 #287484 by chuckp47
Replied by chuckp47 on topic LinuxCNC on Raspberry Pi 5
It would be great if you could point me to some appropriate build instructions. I can look at the driver.  I'm plenty familiar with building Linux, but I'd love to have a pointer to the exactly correct repos.  I haven't easily found this on this forum yet.
Last edit: 07 Dec 2023 22:23 by chuckp47. Reason: More detailed request
  • Platinum Member
  • Platinum Member
07 Dec 2023 22:30 #287491 by Cant do this anymore bye all
You'll have to dive into the RP1 as the IO has been moved off the BCM2712, the RPi4 had the IO on the BCM2711.
I had a bit of play but decided to move to another setup.
linuxcnc.org/docs/html/code/building-linuxcnc.html
datasheets.raspberrypi.com/rp1/rp1-peripherals.pdf
datasheets.raspberrypi.com/bcm2711/bcm2711-peripherals.pdf
github.com/raspberrypi/utils/tree/master/pinctrl
09 Dec 2023 00:48 - 09 Dec 2023 00:52 #287603 by thadwald
Replied by thadwald on topic LinuxCNC on Raspberry Pi 5
rodw post=285989 userid=20660
Well there is an image here crying out for testing. Its based on the official 2.9.1 image for the PI 4B just compiled for the different BCM2112 board.It should work based on cornhlio's comments.
drive.google.com/file/d/1H_q0Ra-27ZDOhqu...x1f/view?usp=sharing
After booting this image, I am greeted by the Debian login screen. What is the username and password?
Last edit: 09 Dec 2023 00:52 by thadwald.
  • Moderator
  • Moderator
09 Dec 2023 01:29 #287605 by tommylight
Replied by tommylight on topic LinuxCNC on Raspberry Pi 5
3 pages back on this topic:
forum.linuxcnc.org/9-installing-linuxcnc...pi-5?start=20#285774
  • rodw
  • rodw's Avatar
  • Platinum Member
  • Platinum Member
09 Dec 2023 02:36 #287606 by rodw
Replied by rodw on topic LinuxCNC on Raspberry Pi 5
usr cnc
pw  cnc
The following user(s) said Thank You: thadwald
09 Dec 2023 04:02 #287607 by thadwald
Thanks.
First thing I notice is display is limited to 640 x 480 and I cannot change it via the Display GUI.
09 Dec 2023 04:07 #287608 by thadwald
By the way, DigiKey has over 2500 pi5 4GB in stock. $60 plus shipping.
  • Platinum Member
  • Platinum Member
09 Dec 2023 04:39 #287609 by Cant do this anymore bye all
Yep the display is an issue.
I started with downloads.raspberrypi.com/raspios_arm64/...ookworm-arm64.img.xz
Installed XFCE desktop, used the config to use X instead of wayland then built a RT kernel to suit.
Time to create page: 0.458 seconds
