LinuxCNC on Raspberry Pi 5
09 Dec 2023 16:43 #287690 by chuckp47
Replied by chuckp47 on topic LinuxCNC on Raspberry Pi 5
This image can be downloaded from here
drive.google.com/file/d/16kKamxMKPdYAeJp...KLf/view?usp=sharing
I installed this and it's quite nice.  Much like the default Pi release, everything came up normally.  The latency historgram looks good.  I'm trying to talk to a Mesa 7c81.  After I set it up for an XZ lathe I get this error report when launch.  The key part seems to be:
Note: Using POSIX realtime
hm2_rpspi: Can't map peripherals: Invalid argument
hm2_rpspi: cannot map peripheral memory.
hm2_rpspi: rtapi_app_main: Invalid argument (-22)
./my_LinuxCNC_machine.hal:9: waitpid failed /usr/bin/rtapi_app hm2_rpspi
./my_LinuxCNC_machine.hal:9: /usr/bin/rtapi_app exited without becoming ready
./my_LinuxCNC_machine.hal:9: insmod for hm2_rpspi failed, returned -1
One of you can probably point out how to correct the memory management.  Suggestions?  There are less errors on the rspi than in the past.  Maybe if I get the memory setup right it can load the rspi driver?
ulimit -l reports 1030416, much bigger than the 20480 noted in the build document.
09 Dec 2023 17:21 #287695 by chuckp47
Reading the errors again, these are all about rspi. That's the same as I had in Rod's image.
I suspect that the SPI driver is still not capable of what is expected here. Some research into the SPI situation showed me that there are features like chip select support that are not yet available in the RPi 5 (RP1 chip) driver package. This will be something more to look into, both in the how LinuxCNC is using SPI and what the SPI firmware driver for the RP1 chip is doing.
09 Dec 2023 18:49 #287707 by thadwald
Replied by thadwald on topic LinuxCNC on Raspberry Pi 5
So what's the password on that image? I can't seem to find it posted anywhere. cnc didn't work for me.
09 Dec 2023 21:31 #287718 by chuckp47
I used the OS customization in the rpi-img program to set them to my own and it worked. It also connected right up to WiFi.
  • Platinum Member
  • Platinum Member
09 Dec 2023 22:18 #287720 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic LinuxCNC on Raspberry Pi 5
rodw post=287637 userid=20660I did a bit of reading. can you guys try adding this at the beginning of cmdline.txt?
video=HDMI-A-1:1920x1080M@60D
I also noticed that the RT patch 6.1,66 has been released and the 6.1.66 kernel was merged into the 6.1.y branch yesterday so it would be a good time to build another image.
There was no cmdline.txt. Creating one with this line didn't change anything.
cmdline.txt is in a subfolder of /boot
  • Platinum Member
  • Platinum Member
09 Dec 2023 22:42 - 10 Dec 2023 01:14 #287724 by Cant do this anymore bye all
OK it has nothing to do with ulimit.
If you look at the source and do some investigation you find to begin with the driver is detecting the board as a RPi3. Therefore the driver is trying to use a memory location that is completely wrong. I raised this issue on github, along with a few experiments I've made but as of yet no replies other than my own have been made. The hm2_rpspi driver takes over from the kernel driver for spi, in fact it unloads the spi_bcm2835 driver.
If you really want to investigate further the first thing you'll need to do is setup all the required dependencies to build Linuxcnc from source.
I dont know where you got the info regarding the chip select line from. The hm2_spi driver will communicate via SPI when using halrun, unfortunately when being used in a config the driver is not fast enough. This is due to the fact that this driver uses the linux kernel SPI driver, and this is actually noted in the man page for that driver.
The GPIO interface has changed to such a degree, the RPi5 will not work with many of the utils & libraries that access the GPIO on the RPi4.
And yes I do have access to boards that run both 7i90 & 7c81 firmware that run fine on a RP-400.
[/quote]
[/quote]
Last edit: 10 Dec 2023 01:14 by Cant do this anymore bye all. Reason: changed hm2_7i90 to hm2_spi
09 Dec 2023 23:31 #287729 by chuckp47
Thanks. I realized I was wrong about the memory right after posting. The RPi peripherals project (firmware for RP1) says that it's not complete, and CS is one of the things missing. I'm just guessing from my previous experience with SPI that missing CS could be important. If no one else gets to it first I'll get to building the whole thing. Gotta start somewhere.
  • Platinum Member
  • Platinum Member
10 Dec 2023 01:13 #287732 by Cant do this anymore bye all
Do you have a link to "The Rp1 peripherals project" ?
I 've gone thru the draft docs for the RP1 and couldn't find any reference to CS being missing. Nor could I have find any reference to the 2 M3 cores being user accessible, the docs show the memory for the RP1 cores being ROM.
As I said the CS seems to work as the hm2_spi (whic I mixed up with h2_7i90 which is the EPP driver) driver works fine within the context of a halrun session, but not within the context of a running config.
10 Dec 2023 02:40 - 10 Dec 2023 02:42 #287736 by chuckp47
I don't know that it's chip select.  That's educated speculation.  I believe it's true that the 7c81 requires a SPI connection.  I did some research last night by talking with google's "Bard".  This is what I got.  After the summary, I asked Bard where it found the information. The links to the projects are there.  (Sorry about the cut and paste formatting)
Bard" on RP5 SPI driver
Unfortunately, the Raspberry Pi 5 RP1 driver does not fully support SPI at this time. While basic SPI functionality is available, there are some limitations and missing features:Limitations:
Last edit: 10 Dec 2023 02:42 by chuckp47. Reason: formatting
  • Platinum Member
  • Platinum Member
10 Dec 2023 04:40 - 10 Dec 2023 04:44 #287741 by Cant do this anymore bye all
There's no need to "believe" that the 7c81 uses the SPI it does, unless you change the firmware for EPP and cook up a custom connector & use the hm2_7i90 driver to talk to the 7c81 over the parallel port.
github.com/jncronin/rpi-boot The last commit was in Feb 16 of 2022 I don't get why this is relevant.
www.abelectronics.co.uk/kb/article/2/spi...ux-on-a-raspberry-pi is well out of date
www.tomshardware.com/reviews/raspberry-pi-5 is just a run of the mill blurb on the RPi5, there is no mention of SPI.
github.com/raspberrypi/firmware/issues Has no issues related to the RPi5 & SPI
The resources you listed aren't really that helpful. The fact that the RP1 documentation isn't mentioned is absolutely astonishing. Next time could you you actually look through any resources you are given and sort out what is relevant and what is not. A few predate the release of the RPi5.
And as far as my research has led me, there is no "RP1" driver (although I havent played with the latest kernel), the SPI side is covered by the spi_bcm2835 driver. The hm2_spi driver uses this.
Another thing that is an issue in the hm2_rpspi driver is where it gathers the information for the clock, it's in a different location.
Actually I'm going to blow out of this part of the discussion. Good luck & all the best.
If you really want to get the attention of the devs your best course of action would to be raise an issue on github or via the emc mailing lists, the relevant information for those resources can be found on the Linuxcnc homepage.
Last edit: 10 Dec 2023 04:44 by Cant do this anymore bye all.
Time to create page: 0.245 seconds
