- Thank you received: 217
A comment on the commit "fix checking for linuxcnc version I hope"
If I set the localization to en, then it works for me. But with German locale if didn't work because your query gives this:
Code:$ apt-cache policy linuxcnc-uspace linuxcnc-uspace: Installiert: 1:2.8.3
Not sure how to get this fixed multilangual.
I just pushed a fix for the missing variables.Commit 2856f614c7344279b0e23974c6ddcdba04794c81 "add output invert for 7i96s"
produces the following error message with my config:
Code:File machine.py line 122, in function daughterCardChanged Error: name 'MAIN_BOARDS' is not defined ["NameError: name 'MAIN_BOARDS' is not defined\n"] Furthermore it would be good if unknown key value pairs (like "BACKLASH = 0.01") are not removed when generating the config. Maybe you can add a special section for that? Or remember the lines which didn't correspond to a supported value and print them when generating? This would also allow to keep comments.
I changed the way I check for LinuxCNC version that should be language agnostic so if you can test that on your PC with the German locale and let me know if you get the correct LinuxCNC version.A comment on the commit "fix checking for linuxcnc version I hope"
Code:$ apt-cache policy linuxcnc-uspace linuxcnc-uspace: Installiert: 1:2.8.3 Not sure how to get this fixed multilangual.
