- Thank you received: 599
At this time I only have the code base for one daughter card... in the future I'll work on two daughter cards.Some other annotations:
- When I select a firmware like 5i25_7i85sx2 - shouldn't it be generally possible to select two daughter cards?
- And these drop down menus are empty for me:
- Backups - This could be understood as backup of the firmware because of the layout. Maybe change the text to "Enable Configuration Backups"
- It creates some non-existing pins the the HAL file:
Code:hm2_5i25.0.7i85s.0.1.analogena hm2_5i25.0.7i85s.0.1.analogout0-scalemax hm2_5i25.0.7i85s.0.1.analogout0-minlim hm2_5i25.0.7i85s.0.1.analogout0-maxlim hm2_5i25.0.7i85s.0.1.analogout0
Code:In Axes I have to provide values for the PID controller. I think the config generation shouldn't fail I don't provide PID parameters in case I don't want to use a PID controller.
:+1:Backup text changed to be clearer what the function is.
I'll have to see why those pins are created for the 7i85s, can you attach your ini file?
Mesa cards need the PID so it's required.
This works nowI changed the way I check for LinuxCNC version that should be language agnostic so if you can test that on your PC with the German locale and let me know if you get the correct LinuxCNC version.
In the display section e.g. there so many possibilities to customize the GUI which makes no sense to have this all in your config tool.What section would key value pairs be in that are not LinuxCNC specific? BACKLASH is a joint specification which could be added to the tool easy enough.
The custom.hal file is not changed by the tool when saving, it only creates it if requested and not in the configuration directory.
