Mesa Configuration Tool
3 years 7 months ago #266834 by freemoore
Replied by freemoore on topic Mesa Configuration Tool
Hi JT & all,
I just found Mesact and it looks really promising; thank you for making it!
I have a 7i80HD-16 and want to configure it for a 7i52S. I have the bitfile (7i80hd_16_svst6_6_7i52s.bit), and the relevant pinfile I think is PIN_SVST6_6_7I52S_48.vhd.
When I choose that firmware from the drop down menu, I get the message 'No pin file found for 7i80hd_16_svst6_6_7i52s.bit' and 'No description file found for 7i80hd_16_svst6_6_7i52s.bit'.  I tried to get mesact to see the pinfile by following the naming convention you have in the 5i24 folder of mesact's github page; I renamed the PIN....vhd file to 7i80hd_16_svst6_6_7I52s.pin and copied to the /.local/lib/libmesact/7i80hd16/ directory.
The daughter card menus remain empty, and I can't continue with building a config until I've selected a daughtercard.
Is there a way of adding pinfile or description info so that mesact will see it?
Many thanks!
Andy
3 years 7 months ago #266844 by freemoore
Had a bit more time, looked closer - the pinfile is the output of readhmid, is this correct? I've replaced the contents of my 7i80hd_16_svst6_6_7i52s.pin file with readhmid's output, and now mesact's pinfile window shows the config properly.
However I still get 'No description file found' for 7i80hd_16_svst6_6_7i52s.bit' and can't select a daughter card; the P1 and P2 menus aren't populated/are unresponsive. Axes & I/O tabs are also greyed out.
What's my next step?
Also, is there a way to save progress, even if currently the config won't build?
thanks,
Andy
3 years 7 months ago #267293 by JT
Replied by JT on topic Mesa Configuration Tool
Sorry, I've been off line for a while with no internet connection.
At this time it must be a valid config to build but it sounds like a good idea to be able to save the ini only if the config won't build.
JT
The following user(s) said Thank You: itsme
3 years 7 months ago #267294 by JT
The pin files and description files are in ~/.local/lib/libmesact/boards/name_of_board
JT
3 years 7 months ago #267476 by JT
thanks,
Andy
Upgrade to version 1.2.4 and you can save the ini file even with errors as long as you have a configuration name. You can then open the ini again later and continue to work on it. Once you don't have any errors the hal files will build as well.
JT
3 years 6 months ago #268519 by ecom
Replied by ecom on topic Mesa Configuration Tool
I installed the version 1.2.4.
Please help me how to configure multiple (two) motors for Y axis?
Time to create page: 0.135 seconds
