Hello,
I assume I'm in the right place, but sorry if not.
I saw a lot of videos like 7i92 and easy-peasy setups and decided to use PC+Mesa instead of smth like SZGH-CNC990(1000)TDb-*.
I have a lathe with the servo (HLTNC HL-T3D driver + motor brake) in Spindle + 2 step motors (for now, but same servos in the future in each axis) + step for ACT for another spindle (milling) + at least 2 optical rulers + encoder for spindle (optional, because I'm going receive position from driver for now and rely on this info, but then going to switch to dedicated spindle encoder).
So I bought 7i95T. And install LinuxCNC and... Pncconf wizard doesn't work with new boards because of PIN naming (as I understand) and this is only the beginning. That's why I need (correct me, if I'm wrong) MesaCT. Am I in the right direction? Or do I have to fix somehow Pncconf (the main problem is that XML connector name is NOT "P1", but "STEP/DIR+ENCODER+I/O" and python to int convert issue)?
