Mesa Configuration Tool
- JT
- Thank you received: 593
25 Mar 2023 17:06 #267476
by JT
JT
Replied by JT on topic Mesa Configuration Tool
Upgrade to version 1.2.4 and you can save the ini file even with errors as long as you have a configuration name. You can then open the ini again later and continue to work on it. Once you don't have any errors the hal files will build as well.Also, is there a way to save progress, even if currently the config won't build?
thanks,
Andy
JT
- ecom
07 Apr 2023 14:54 #268519
by ecom
Replied by ecom on topic Mesa Configuration Tool
I installed the version 1.2.4.
Please help me how to configure multiple (two) motors for Y axis?
- JT
15 Apr 2023 12:20 #269100
by JT
Press F1 while the Axes tab is visible.
JT
JT
- CWALV_Puzzle
11 May 2023 19:25 #271172
by CWALV_Puzzle
Thank you, I really like the format of mesact.
Replied by CWALV_Puzzle on topic Mesa Configuration Tool
I am using an mx4660 with a 7i92. I have the .bin and .pin files in the above location. The daughter card menus remain empty, and I can't continue with building a config until I've selected a daughtercard. Any way past this?The pin files and description files are in ~/.local/lib/libmesact/boards/name_of_board
JT
- JT
11 May 2023 19:34 - 11 May 2023 19:37 #271174
by JT
Unfortunately MesaCT the daughters are hard coded, this is one of the many things I'm improving in MesaCT II. For now I'll have to add the MX4660, what version of MesaCT are you using?
I can add that in the morning... or just select the 7i92_5ABOBx2D.bit firmware and you can pick a stepper daughter card.
JT
JT
Last edit: 11 May 2023 19:37 by JT.
- CWALV_Puzzle
11 May 2023 20:09 #271176
by CWALV_Puzzle
Thank you, I'm on 1.2.4 downloaded today. I should have thought to check the source code.
Separating that from the source code sounds like a good idea. I will play around with the bob file, do I have to change to that firmware on the card as well or will it work to fudge it?
- JT
11 May 2023 21:50 #271180
by JT
No need to change the firmware on the card. The original idea was to make sure the correct firmware was selected but that proved to be problematic to program.
JT
JT
- CWALV_Puzzle
13 May 2023 03:13 #271273
by CWALV_Puzzle
Got it to build a config with the BOB settings. LinuxCNC complains about pwmgen.06.enable missing and won't start.
I will dig into it tomorrow.
- Mattias
16 Feb 2024 11:28 - 16 Feb 2024 15:27 #293500
by Mattias
Replied by Mattias on topic Mesa Configuration Tool
I am moving my thread to this topic on advice from the moderators because my issues are MesaCT related.
Previous topic: Configuration problems 7i95t Mesa card with servo drives.
First, thanks in advance for all the help from this helpful community!
My situation is as follows: I have a Mesa 7i95T board (firmware: 7i95t_1pwmd.bin) to run T6 400w servo motors on my diy cnc router for cutting wood and aluminum.
I am running linuxCNC 2.9.1 amd 64 on Debian from this official website on a Lenovo thinkCenter small PC. And i am using MesaCT 2.1.2 to make the configuration but the configuration are only partially generated. I am missing the stepgen and all the axis/joints configurations. I have disabled secure mode in BIOS. I have reinstalled Linux and MesaCT two times. And logically i get folowing errors in linuxcnc trying to run these config files.
I am kind of lost for options to try which makes my whole build kind of in stuck. So all the help i can get will be much appreciated.
Thanks and kind regards,
Mattias
Mattias
Last edit: 16 Feb 2024 15:27 by Mattias.
- JT
18 Feb 2024 16:24 - 18 Feb 2024 16:27 #293686
by JT
I'll look into this, the fastest way is to create a bug report.
All I need to recreate your configuration is the ini file.
The ini file is from 2.1.1...
JT
JT
Last edit: 18 Feb 2024 16:27 by JT.
The following user(s) said Thank You: Mattias
Time to create page: 0.340 seconds
