Ethercat HAL driver
5 years 10 months ago #192956 by jc2ktr
chimeno wrote: Hello @jc2ktr
I'm sure it's silly, I can't think of anything myself, you can publish your .hal files and I'll take a look at it
Greeting
Chimeno
@Chimeno
i think it's can't be that big mistake, but i don't see it / get it what the problem is. My complete config is attached.
The Gui starts and the mapped IO's are shown in HAL-Show, and the drive can be enabled but will not move.
Greetings Sven
File Name: my-mill_12...0.tar.gz
File Size:6 KB
5 years 10 months ago #193012 by chimeno
Hello @jc2ktr,
I can't find the configuration signals?
setp lcec.0.7.opmode 8 setp lcec.0.7.X-cmd-OPmodeRel1 1
Greeting
Chimeno
5 years 10 months ago - 5 years 10 months ago #193014 by jc2ktr
chimeno wrote: Hello @jc2ktr,
Greeting
Chimeno
The lcec.0.7.opmode 8 is set in the custom_postgui.hal under only under another name setp lcec.0.7.opmode-3 true
its defined in the ethercat.xml <pdoEntry idx="6060" subIdx="00" bitLen="8" halPin="opmode" halType="bit"/>
the other one i must have missed in my config, though i dont really know what it does at the moment.
addition
the setp lcec.0.7.X-cmd-OPmodeRel1 1 < i have renamed it as i added some changes from MRBaird
addition 2
is it possible that the drive does not move because the joint.0.acc-cmd does not change its state it remains allways 0 when i jog the axis
Last edit: 5 years 10 months ago by jc2ktr. Reason: picture added
5 years 10 months ago #193018 by chimeno
Hello @jc2ktr
Ok, I don't know what else to tell you, check that the engine moves with TWINCAT3 and check the status that is the same in linuxcnc, you will have to ask for help from the colleague @MRBaird that he does have the drivers and can help you
Greeting
Chimeno
The following user(s) said Thank You: jc2ktr
5 years 10 months ago #193024 by jc2ktr
Hello @jc2ktr
Greeting
Chimeno
Hello @Chimeno
Thank you i will try it further and ask also @MRBaird.
Although i want to Thank you for your great kindness and the really good help. :)
Wish you Merry Christmas and much luck :)
The following user(s) said Thank You: chimeno
5 years 10 months ago - 5 years 10 months ago #193034 by chimeno
Hello @jc2ktr
I think the problem is that it lacks the speed at which it has to move, register this pin
<syncManager idx="2" dir="out"> <pdo idx="1600"> <!-- Target Velocity --> <pdoEntry idx="60ff" subIdx="00" bitLen="32" halPin="TargetVelocity" halType="float" scale="1000"/> net xvel-cmd => lcec.0.7.TargetVelocity
Merry Christmas
Chimeno
Last edit: 5 years 10 months ago by chimeno. Reason: Edit
Time to create page: 2.110 seconds
