Ethercat HAL driver
- bkt
- Thank you received: 114
25 Feb 2021 17:38 #200120
by bkt
Replied by bkt on topic Ethercat HAL driver
You are in right ...... I'm sorry I didn't notice this ..... so the problem is that once Linuxcnc is turned off the drives go into PREOP. This is OK. But sometime when I start Linuxcnc they don't return to OP.
The problem is this.
I confirm that estop and other signals work as you said.
The drives are Maxine Ep3.
After this problem has appeared I can reset everything just by putting the drives in init or by turning off the power supply of the drives and after a few seconds turning on again.
bkt
bkt
- db1981
- Thank you received: 276
25 Feb 2021 18:03 #200122
by db1981
Replied by db1981 on topic Ethercat HAL driver
best way would be to find out why they don't go to op again.
Next time this is, check the dmesg log. There must be ethercat information. unable to assign pdo, unable to set dc conf etc....
The following user(s) said Thank You: bkt
- db1981
25 Feb 2021 18:13 #200124
by db1981
Ethercat version is EP 3E? is there anywere an english manual?
- bkt
25 Feb 2021 20:04 - 25 Feb 2021 20:16 #200128
by bkt
tomorrow is send you one pdf copy ... now I can't.
I understand the best way is to control dmesg ..... but I usually look for the shortest and safest way .... re-initializing everything seems pretty safe to me. Certainly it is inconvenient, but I have also had similar problems with bechkoff plc in the past .... I got the idea that it is a common problem with some types of intel chipset rj45 ports, used on small bechkoff plcs, on my pc and on EP3E drives.
bkt
bkt
Last edit: 25 Feb 2021 20:16 by bkt.
- bkt
01 Mar 2021 08:51 #200514
by bkt
Sorry but administrator settings not permit upload file more big than 1.6Mb ..... I I split manual into 4 part.
- besriworld
- Thank you received: 92
06 Mar 2021 22:24 #201227
by besriworld
Replied by besriworld on topic Ethercat HAL driver
Hello ,
I have a question . I bought servo motors/driver with EtherCAT, but they are not supported by the HAL driver. I need to use a generic driver . Will I have a problem with latency? I have three drivers for 3axis Mori Seiki MV-JR
I am attaching the hml file for drivers (Adatech model QXEH10NE)
- db1981
07 Mar 2021 00:45 #201239
by db1981
Hello,
it makes no difference using the generic or an already programmed driver. All Slave Data is read and written once per rt cycle period.
- jc2ktr
- Thank you received: 17
07 Mar 2021 09:38 #201266
by jc2ktr
Replied by jc2ktr on topic Ethercat HAL driver
@db1981
you mentioned in an earlier Post that it is Possible to use EOE in LinuxCNC do you have any Expirience with it?
I tried to set it up but i am stuck.
I tried it with these Steps.
sf.net Etherlabmaster EOE
- db1981
07 Mar 2021 11:02 #201277
by db1981
hello jc2ktr,
the terminal command "ethercat eoe" still doesn't work ?
please go to your ec-debianize folder an do a test run of the get source scripts
"./get_source.sh". it clones the repository and then a full screen of patches have to be applied... or is the patching skipped?
- jc2ktr
07 Mar 2021 11:39 - 07 Mar 2021 11:40 #201279
by jc2ktr
no ethercat eoe still shouts out this:
lcnc@LinuxCNC-M75q:~/ethercat_debianize$ ethercat eoe
Unknown command eoe!
and ./get_source.sh this:
lcnc@LinuxCNC-M75q:~/ethercat_debianize$ sudo ./get_source.sh
Cloning HG commit 33b922...
Füge Änderungssätze hinzu
Füge Manifeste hinzu
Füge Dateiänderungen hinzu
Fügte 2112 Änderungssätze mit 8177 Änderungen an 1502 Dateien hinzu
new changesets 05c992bf5847:33b922ec1871
Aktualisiere auf Zweig default
1116 Dateien aktualisiert, 0 Dateien zusammengeführt, 0 Dateien entfernt, 0 Dateien ungelöst
Cloning patchset commit 8ea394...
Fügte 13 Änderungssätze mit 528 Änderungen an 310 Dateien hinzu
new changesets 93020352c612:8ea39404a2e8
145 Dateien aktualisiert, 0 Dateien zusammengeführt, 0 Dateien entfernt, 0 Dateien ungelöst
Apply patchset...
Wende stable/0001-update_ccat_driver_to_v0_13.patch an
Wende stable/0002-fix_ccat_startup_stall_in_case_the_dma_memory_was_allocated_above_4_gb_limi.patch an
Wende stable/0003-update_ccat_driver_to_v0_14.patch an
Wende stable/0004-prevent_ccat_auto_loading.patch an
Wende stable/0005-fixed_fragmented_soe_write_request.patch an
Wende stable/0006-adapted_vm_operations_struct_for_kernels_4_11.patch an
Wende stable/0007-fixed_vm_fault.patch an
Wende stable/0008-forgot_makefile_orig.patch an
Wende stable/0009-do_not_build_gpio_part_of_ccat_if_gpio_is_not_configured_in_kernel.patch an
Wende stable/0010-added_clean_igb_driver_from_kernel_3_18_no_ethercat_yet.patch an
Wende stable/0011-ethercat_functionality_of_igb_driver.patch an
Wende stable/0012-doc.patch an
Wende stable/0013-fixed_statistics_filter_initialisation.patch an
Wende stable/0014-respect_bashisms.patch an
Wende stable/0015-mention_igb_driver_in_config_files.patch an
Wende stable/0016-added_missing_configure_options_to_documentation.patch an
Wende stable/0017-support_scheduler_parameters_in_kernels_4_11.patch an
Wende stable/0018-improved_buffer_overflow_messages.patch an
Wende stable/0019-ignore_missing_sdo_entries_in_output.patch an
Wende stable/0020-applied_ccat_patch_0001_fix_ccat_netdev_for_v4_11_patch_from_beckhoff.patch an
Wende stable/0021-applied_0002_use_setup_timer_for_v4_15_patch_from_beckhoff.patch an
Wende stable/0022-use_sched_setscheduler_to_set_priority_in_user_example.patch an
Wende stable/0023-fixed_scheduler_settings_in_dc_user_example_use_clock_monotonic.patch an
Wende stable/0024-do_not_call_watchdog_function_while_frames_are_received.patch an
Wende stable/0025-set_enable_sii_assign_by_default.patch an
Wende stable/0026-fixed_typo.patch an
Wende stable/0027-todo.patch an
Wende stable/0028-added_8139too_for_kernel_4_4.patch an
Wende stable/0029-added_native_igb_driver_for_kernel_4_4.patch an
Wende stable/0030-checked_usage_of_last_rx_timestamp_for_stats_fixed_indentation.patch an
Wende stable/0031-added_e100_driver_for_kernel_4_4.patch an
Wende stable/0032-added_r8169_driver_for_kernel_4_4.patch an
Wende stable/0033-minor_fix.patch an
Wende stable/0034-added_e1000_driver_for_kernel_4_4.patch an
Wende stable/0035-renamed_app_start_time_to_dc_ref_time_output_via_command_line_tool.patch an
Wende stable/0036-added_ecrt_master_sync_reference_clock_to_method.patch an
Wende stable/0037-minor_dc_diagnosis_layout.patch an
Wende stable/0038-bumped_library_version.patch an
Wende stable/0039-use_ecrt_master_sync_reference_clock_to_in_dc_examples.patch an
Wende stable/0040-changed_default_prefix_to_usr_local.patch an
Wende stable/0041-added_e1000e_driver_for_kernel_4_4.patch an
Wende stable/0042-added_floating_point_access_functions_and_macros_for_user_space.patch an
Wende stable/0043-added_missing_const_specifier_to_ecrt_read_real_ecrt_read_lreal.patch an
Wende stable/0044-added_extern_c_for_floating_point_functions.patch an
Wende stable/0045-fixed_memory_leak_concerning_library_ecrt_master_deactivate.patch an
Wende linux/0001-debugif-3.17.patch an
Wende linux/0002-kern_cont.patch an
Wende linux/0003-vm_fault-4.10.patch an
Wende linux/0004-signal-4.11.patch an
Wende linux/0005-tty-4.15.patch an
Wende devices/0001-update.patch an
Wende devices/0002-update.patch an
Wende devices/0003-e1000e-link-detection.patch an
Wende devices/0004-linux-3.18.patch an
Wende devices/0005-linux-4.1.patch an
Wende devices/0006-linux-4.4.patch an
Wende devices/0007-linux-4.9.patch an
Wende devices/0008-linux-4.14.patch an
Wende devices/0009-linux-4.19.patch an
Wende devices/0010-cx2100-2.6.patch an
Wende devices/0011-cx2100-4.9.patch an
Wende devices/0012-e1000-unused-variable.patch an
Wende devices/0013-r8152-4.9.patch an
Wende devices/0014-r8152-3.18.patch an
Wende devices/0015-r8152-4.4.patch an
Wende base/0000-version-magic.patch an
Wende base/0001-Distributed-Clock-fixes-and-helpers.patch an
Wende base/0002-Distributed-Clock-fixes-from-Jun-Yuan.patch an
Wende base/0003-print-sync-signed.patch an
Wende base/0004-fix-eoe-clear.patch an
Wende base/0005-disable-eoe.patch an
Wende base/0006-avoid-ssize_t.patch an
Wende base/0007-replace-fprintf-calls-with-EC_PRINT_ERR.patch an
Wende base/0008-read-reference-slave-clock-64bit-time.patch an
Wende base/0009-Avoid-changing-running-slaves-DC-offset.patch an
Wende base/0010-Make-busy-logging-a-little-less-irritating.patch an
Wende base/0011-Reduced-printing-to-avoid-syslog-spam.patch an
Wende base/0012-Added-newline-to-syslog-message-MAC-address-derived.patch an
Wende base/0013-Do-not-reuse-the-index-of-a-pending-datagram.patch an
Wende base/0014-Fix-NOHZ-local_softirq_pending-08-warning.patch an
Wende base/0015-Clear-configuration-on-deactivate-even-if-not-activa.patch an
Wende base/0016-If-enable-rtmutex-use-rtmutexes-instead-of-semaphore.patch an
Wende base/0017-Master-locks-to-avoid-corrupted-datagram-queue.patch an
Wende base/0018-Use-call-back-functions.patch an
Wende base/0019-Support-for-multiple-mailbox-protocols.patch an
Wende base/0020-eoe-ip.patch an
Wende base/0021-Await-SDO-dictionary-to-be-fetched.patch an
Wende base/0022-Clear-slave-mailboxes-after-a-re-scan.patch an
Wende base/0023-Skip-output-statistics-during-re-scan.patch an
Wende base/0024-Sdo-directory-now-only-fetched-on-request.patch an
Wende base/0025-Ignore-mailbox-settings-if-corrupted-sii-file.patch an
Wende base/0026-EoE-processing-is-now-only-allowed-in-state-PREOP.patch an
Wende base/0027-Prevent-abandoning-the-mailbox-state-machines-early-.patch an
Wende base/0028-ec_master_exec_slave_fsms-external-datagram-fix.patch an
Wende base/0029-Tool-Withdraw-EEPROM-control-for-SII-read-write.patch an
Wende base/0030-Print-redundancy-device-name-with-ring-positions-as-.patch an
Wende base/0031-ext-timeout.patch an
Wende base/0032-dc-sync1-offset.patch an
Wende features/xenomai3/0001-Support-Xenomai-version-3.patch an
Wende features/net-up/0001-Add-support-for-bringup-up-network-interface-when-st.patch an
Wende features/sii-cache/0001-Improved-EtherCAT-rescan-performance.patch an
Wende features/sii-cache/0002-Redundancy-name.patch an
Wende features/sii-cache/0003-rescan-check-revision.patch an
Wende features/reboot/0001-Add-command-to-request-hardware-reboot-for-slaves-th.patch an
Wende features/quick-op/0001-After-a-comms-interruption-allow-SAFEOP-OP-directly-.patch an
Wende features/status/0001-Adding-some-more-state-to-avoid-calling-the-more-exp.patch an
Wende features/status/0002-Detect-bypassed-ports-timestamp-not-updated.patch an
Wende features/status/0003-Calculate-most-likely-upstream-port-for-each-slave.patch an
Wende features/status/0004-slave-config-position.patch an
Wende features/rdwr/0001-Add-register-read-write-support.patch an
Wende features/rdwr/0002-Display-more-info-about-the-register-requests-in-pro.patch an
Wende features/complete/0001-Support-SDO-upload-via-complete-access.patch an
Wende features/complete/0002-add-sdo-write-with-size.patch an
Wende features/complete/0003-sdo-requests-complete.patch an
Wende features/master-redundancy/0001-e1000e-fix-watchdog-redundancy.patch an
Wende features/sii-file/0001-load-sii-from-file.patch an
Wende features/diag/0001-ethercat-diag.patch an
Wende features/diag/0002-diag-readwrite.patch an
Wende features/foe/0001-fsm_foe-simplify.patch an
Wende features/foe/0002-foe-password.patch an
Wende features/foe/0003-foe-requests.patch an
Wende features/foe/0004-foe-request-progress.patch an
Wende features/parallel-slave/0001-fsm_sii_external-datagram.patch an
Wende features/parallel-slave/0002-fsm_change-external-datagram.patch an
Wende features/parallel-slave/0003-fsm_slave_config-external-datagram.patch an
Wende features/parallel-slave/0004-fsm_slave_scan-external-datagram.patch an
Wende features/parallel-slave/0005-fsm_slave-handles-all-sdos.patch an
Wende features/parallel-slave/0006-fsm_slave_config_scan-to-fsm_slave.patch an
Wende features/parallel-slave/0007-fsm-exec-simplify.patch an
Wende features/sii-wait-load/0001-slave-scan-retry.patch an
Wende features/sii-wait-load/0002-fsm_sii-loading-check.patch an
Wende features/rt-slave/0001-allow-app-to-process-slave-requests-from-realtime.patch an
Wende features/eoe-rtdm/0001-eoe-addif-delif-tools.patch an
Wende features/eoe-rtdm/0002-eoe-via-rtdm.patch an
Wende features/pcap/0001-pcap-logging.patch an
Wende features/pcap/0002-runtime-size.patch an
Wende features/pcap/0003-report-size.patch an
Wende features/pcap/0004-high-precision.patch an
Wende features/mbg/0001-mailbox-gateway.patch an
jetzt bei: features/mbg/0001-mailbox-gateway.patch
Create source archive...
Extracting source...
DONE.
hello jc2ktr,
Warning: Spoiler!
Apply patchset...
DONE.
Last edit: 07 Mar 2021 11:40 by jc2ktr. Reason: Edit
Time to create page: 2.368 seconds
