Ethercat HAL driver
10 years 10 months ago #66356 by DaPeace
Replied by DaPeace on topic Ethercat HAL driver
Ive used the vmware-macbook just for testing and configuring because the place around the machine is not enough to set it up at the machine-computer. BUT one macbook drives a vm and the other macbook runs linuxcnc nativly.
Both have the same problem. Both use the generic-driver and none of them hast a intel-networkcard.
So you think i will need one of the intel or realtek-cards to use that beckhoff-stuff?
10 years 10 months ago - 10 years 10 months ago #66380 by narogon
Replied by narogon on topic Ethercat HAL driver
DaPeace wrote: Hey Guys, short question: Im playing around with Ethercat-Components at the moment.
I want to get rid of the LPT-Interface of my mill and drive the stepper with EL2024 Output-Clamps and some Buttons with EL1008.
Ive put all together and i see the devices when i run ethercat slaves
I use the generic-driver. I tried an old macbook and a virtual machine on a newer macbook with linuxcnc 2.6 and 2.7. I can list all clamps here too but when i start linuxcnc the complete system hangs and i need to reset the pc.
Do i need one of that intel-nic's or is the generic driver ok for that kind of application?
Is it possible to use the output-clamps for driving step and directions signals at all?
Regards, Jan
Why don't you try to configure the ethercat HAL component from HAL console (executing halrun) before try it with linuxcnc?.
Create a .hal file with
loadusr -W lcec_conf yourXMLfile loadrt lcec loadrt trivkins loadrt motmod base_period_nsec=0 servo_period_nsec=1000000 num_joints=1 addf lcec.read-all servo-thread addf lcec.write-all servo-thread start
You can load the file doing halrun -I halfile.hal and check some values with halscope or halmeter
Best regards.
Last edit: 10 years 10 months ago by narogon.
10 years 10 months ago - 10 years 10 months ago #66389 by DaPeace
Ive now tried that out. Ive used the macbook with native linuxcnc 2.6 and the millingcomputer with 2.7 and i get a kernelpanic on both devices. i can start axis for example with very basic hal-file or i can run halrun and after a while i get that kernalpanic. when its not crashing right after start i can open hal-overview and i can trigger the inputs and see that they are reacting. but after max. 2mins i get that kernel panic.
Following Crashlog i get:
Crashlog
When i put your code into a basic-halfile and start it i get a kernelpanic instantly.
At the end of the trace it says Code: Bad EIP value.
Last edit: 10 years 10 months ago by DaPeace.
10 years 10 months ago #66449 by wazjebk
Replied by wazjebk on topic Ethercat HAL driver
Dear all,
I have the same issue on D525MW motherboard with integrated network card and generic driver. I already try to put inside some other PCI card but I have still same issue as Dapeace - above.
Best regards.
10 years 10 months ago #66456 by DaPeace
Did you try one of the intel-cards and use the e100 or e1000-driver or did you only try another card with generic-driver? I think about getting a intel-card and try out again.
10 years 10 months ago #66460 by wazjebk
I just try another card with generic driver.
Best regards.
Time to create page: 0.174 seconds
