Ethercat HAL driver
- DaPeace
10 years 10 months ago #66465
by DaPeace
Replied by DaPeace on topic Ethercat HAL driver
Ok so there is a chance a intelcard could fix that.. i will try to get one on monday and report here if it works..
if someone has another solutions for that it would be very nice to know
- wazjebk
- Thank you received: 3
10 years 10 months ago #66510
by wazjebk
Replied by wazjebk on topic Ethercat HAL driver
Hi again,
today I once again try pci network card Tenda L8139D together with 8139too driver and system works without crashing now for more than 4 hours. I think that generic driver was not suitable for non of the cards.
Best regards.
Best regards.
The following user(s) said Thank You: Nico2017
- DaPeace
10 years 10 months ago #66511
by DaPeace
Hey wazjebk, same here. changed my vmware-card on the virtual machine to intel and used the e1000e-driver and everything worked fine.
Now i need to order a card for my milling-computer.
Regards, Jan
Regards, Jan
- Thank you received: 7491
10 years 10 months ago #66598
Tom
Replied by tommylight on topic Ethercat HAL driver
That is a Realtek 8139 10/100 net card branded as Tenda, if i had to choose i would run away from Tenda.wazjebk wrote: Hi again,
Best regards.
Tom
- wazjebk
10 years 10 months ago - 10 years 10 months ago #66632
by wazjebk
HI,
I just use this card for testing at the moment. Do you have some bad experience with Tenda? Which network card than you recommend?
Best regards.
Best regards.
Last edit: 10 years 10 months ago by wazjebk.
The following user(s) said Thank You: Markux
10 years 10 months ago #66649
Not me personally, but a lot my customers and friends say the reliability is hit and miss on them, same as TP Link. If they do work properly, they will do that all the time for a looong time, but some have a variety of intermittent problems.
On the other hand the 8029 and 8139 chips from realtech work like a charm, had and use several hundreds of them without a hitch, ever. Well apart from lighting strikes !!!
find intel PRO100 boards from older computers (should be some left on ebay for small change) if you want absolute reliability and compatibility with whatever OS or hardware. They just work.....for years and years without shut down. Also used several hundreds of them especially on servers and some of them have been ON for over 7 years. I think i still have 2 or 3 in my workshop that i left for when reliability must be absolute.
Regards,
Tom
Regards,
Tom
Time to create page: 0.190 seconds
