Ethercat HAL driver
- billiehuijbregts
21 Mar 2016 08:45 - 21 Mar 2016 12:20 #71965
by billiehuijbregts
Replied by billiehuijbregts on topic Ethercat HAL driver
Hi Allen
I attached my current XML file. It uses the <masters> </masters>, otherwise my Ethercat HAL driver did indeed not work.
Just installed Linuxcnc on another computer to be sure, but I still get the same errors. When I loaded my files into the Linuxcnc program I got some errors and I know where the problem is now. Still need to solve it tho.
./danfoss.hal:27: Pin 'lcec.0.0.poscommand' does not exist
[248495.584309] EtherCAT ERROR 0-0: Failed to set SAFEOP state, slave refused state change (PREOP + ERROR).
[248495.584331] EtherCAT ERROR 0-0: AL status message 0x001E: "Invalid input configuration".
[237290.510216] EtherCAT DEBUG: 00 30 4F 12 1C 00 01 00 00 00
Last edit: 21 Mar 2016 12:20 by billiehuijbregts.
- cgc
- Thank you received: 10
21 Mar 2016 13:11 #71982
by cgc
Replied by cgc on topic Ethercat HAL driver
Hello,
that are 16 single bits,
<pdoEntry idx="2692" subIdx="00" bitLen="16" halPin="poscommand" halType="bit"/>
but that are 32 bit float
axis.0.motor-pos-cmd
Frank
Frank
- billiehuijbregts
23 Mar 2016 06:31 - 23 Mar 2016 11:00 #72057
by billiehuijbregts
Dear Frank,
Thanks for the tip! I changed my haltype but I get the error that it's a float and doesn't get converted to a s32.
I used the :
loadrt conv_s32_float
loadrt_conv_float_s32
Should I maybe put my lcec.0.0.pos to the conv_float_s32.0.out pin?
And the pos-command to the conv_float_s32.0.in pin.
I used the :
Last edit: 23 Mar 2016 11:00 by billiehuijbregts.
- cgc
23 Mar 2016 14:00 #72060
by cgc
Hello,
Yes,
you can also use the option "scale" in the *.xml to calculate the unit.
Frank
Yes,
Frank
- cnceng
25 Mar 2016 18:50 #72151
by cnceng
Replied by cnceng on topic Ethercat HAL driver
Please, take a look to this paper: Integration of real-time Ethernet in LinuxCNC link.springer.com/article/10.1007/s00170-015-6786-y
The article uses the example of Sercos III but it works also with EtherCAT and other protocols.
- jpettit
25 Mar 2016 23:49 #72163
by jpettit
Replied by jpettit on topic Ethercat HAL driver
Allen
Andreas Schiffler on youtube has a 3 axis mill with 4th axis runing LinuxCNC using etherCAT
Ethercat coupler--- Modules EL ---and EX see his work
jim Pettit
jim Pettit
- billiehuijbregts
01 Apr 2016 06:27 #72507
by billiehuijbregts
Got my setup almost working now, but still have problems getting my drive to OP.
When I use the ethercat states op command, I get a red led and a communications error because I need to write some values.
I know this and added those values to my xml file with SdoConfig.
But when I start my ethercat HAL driver using the command terminal, load my xml with lcec_conf and load the lcec module, nothing happens.
Seems like my ethercat master doesn't send a request for the state change to OP, because I get no feedback from the drive (leds, display).
Loading the lcec module should request the OP state right?
- roschi
- Thank you received: 29
03 Apr 2016 20:03 - 03 Apr 2016 20:06 #72647
by roschi
Replied by roschi on topic Ethercat HAL driver
due to further development of the ethercat hal driver especially the "lcec_conf", the content / use of the XML changed slightly.
1. XML file should start/end with <masters> ... </masters> (as mentioned in this thread before #71267 )
2. In diffrence to my initial introduction of the "scale" option the haltype "special32" won't work (as mentioned in this thread before #71871 )
3. To use eg. pos / poscommand with type float use the haltype "complex" in XML see examples here:
S. Ittner config examples close to line 99.
Regards Andreas
Regards Andreas
Last edit: 03 Apr 2016 20:06 by roschi.
The following user(s) said Thank You: wazza77, Nico2017
- xk2010
07 Apr 2016 03:55 #72892
by xk2010
Replied by xk2010 on topic Ethercat HAL driver
I had the same questions as shown this.
forum.linuxcnc.org/forum/24-hal-componen...iver?start=168#58343
How to solve this.
Would you help me?
xiekai
How to solve this.
Would you help me?
xiekai
- billiehuijbregts
07 Apr 2016 08:52 #72898
by billiehuijbregts
Dear Xiekai,
I think you can solve that by adding the <masters> </masters> in your XML file, as described one post above yours by Andreas.
Billie
Billie
The following user(s) said Thank You: xk2010
Time to create page: 1.204 seconds
