Ethercat HAL driver
- plopes9000
- Thank you received: 18
10 Aug 2017 10:17 #97298
by plopes9000
Replied by plopes9000 on topic Ethercat HAL driver
What puzzles me is how could this github.com/sittner/linuxcnc-ethercat/blo.../ethercat-conf_X.xml have ever worked ... I can only assume that the backup parameter was used to store the canopen slaves configuration so that it's available at preop just after boot, hence caught in the igh ethercat initial bus scan. But I did try the backup parameter without success - though I'm not sure I did it properly . . .
- sirop
- Thank you received: 57
10 Aug 2017 10:24 #97299
by sirop
Replied by sirop on topic Ethercat HAL driver
You can also doafter the first (unsuccessful) launch.
BTW, last time I tied to use OCTET_STRING from cmd, I did not really succeed:
lists.etherlab.org/pipermail/etherlab-users/2016/003094.html .
ethercat rescanBTW, last time I tied to use OCTET_STRING from cmd, I did not really succeed:
- plopes9000
10 Aug 2017 10:41 #97301
by plopes9000
The goal is to be able to boot the pc and launch linuxcnc without manual steps.
Thanks Boris. I will keep trying when I'm back home.
- sqmathlete
13 Aug 2017 15:05 #97415
by sqmathlete
Replied by sqmathlete on topic Ethercat HAL driver
Hi Sirop,
I dug deeper as you suggested into the AKD example. Ran the bash example code and managed to output ethercat cstruct. (I have attached the file) As you can see there is some info at the top enabling the syncManagers which makes sense because I see the amplifier (Delta ASDA-A2E) in the preop state in LinuxCNC and cannot make it switch states or interact with it at all.
Q1. Is the file outputted by the cstruct command the "glue module" referred to here?
wiki.linuxcnc.org/cgi-bin/wiki.pl?Etherlab.
Q2. Does this info also need to be included in the xml file and if so how would it be parsed?
Q3. To all. Show of hands how many people have a working machine? Working on a bench?
- sqmathlete
13 Aug 2017 15:30 #97417
by sqmathlete
Hi Naragon,
Not sure if you posted these files somewhere but I am having a similar issue intializing the amplifiers. Are you using Delta ASDA-A2E amps?
Kind Regards,
Dan
Kind Regards,
Dan
- sirop
13 Aug 2017 15:59 - 13 Aug 2017 16:00 #97420
by sirop
You can go the way described in wiki.linuxcnc.org/cgi-bin/wiki.pl?Etherlab , that would mean that you code your own EtherCAT component.
Or you use linuxcnc-ethercat which you need an XML description file for. Its format is different from the output of ethercat xml,
but the the information it contains is more or less the same.
I doubt that you can simply switch to operational phase by the means of etherlab cmd tool. But you can probably use sdo commands like ethercat download/upload to read and write values already in the PREOP phase.
Hi Sirop,
Last edit: 13 Aug 2017 16:00 by sirop. Reason: typo
- sqmathlete
13 Aug 2017 16:49 #97423
by sqmathlete
"Or you use linuxcnc-ethercat which you need an XML description file for. Its format is different from the output of ethercat xml, but the the information it contains is more or less the same"
Can you expand a bit more on this? Where would one find/put this second xml file? I have a configuration of beckhoff input/output terminals and don't see anything in my notes about having this second xml file.
and yes, commands like ethercat upload/download seem to read and write values in the PREOP phase through the terminal.
- sirop
13 Aug 2017 17:15 #97425
by sirop
I just wanted to say that the format of, for instance, github.com/sittner/linuxcnc-ethercat/blo...ex/ethercat-conf.xml is different from the output of ethercat xml, but the information is in both cases almost the same.
It describes your EtherCAT configuration ( of every slave involved).
In your HAL script you do then:
loadusr -W lcec_conf ethercat-conf.xml
loadrt lcecPlease Log in or Create an account to join the conversation.
- sqmathlete
13 Aug 2017 19:14 #97430
by sqmathlete
Okay, that makes more sense. Another question, in sittners example github.com/sittner/linuxcnc-ethercat/blo.../ethercat-conf_X.xml line 76-77 the SDO data the control word 6040 is reversed. Is this because of this infosys.beckhoff.com/english.php?content...mServiceData.htm&id=
That is, in a client > server download request the bytes 0-3 of user data is indexed from the LSB but data object 4 is indexed from the MSB?
For example the default PDO mapping (as seen in Twincat )of the Delta ASDA-A2E amps is as follows
1st RxPDO 0x1600
0x6040:00 size =2 offs = 0.0 Control word
0x607A:00 size=4 offs = 2.0 Target Position
0x60FF:00 size =4 offs = 6.0 Target Velocity
0x6071:00 size=2 offs = 10 Target Torque
0x6060:00 size=1 offs=12 Mode of Operation
To write the SDO data for 6040 control word like sittners example would be and following the beckhoff example for client-.server download request
line 75
<sdoDataRaw "40 60 00 02 00 80 00" />
which, if I understand correctly breaks down to
40 60 = index1 msb first, since index 0 = pdo index 0x1600
00 = sub index,
02 = data size (16bits),
00 80 = value
00 = ????
I still can't seem to get the amp to come in to the OP state. Guessing that there is something in the inintial sdo set up that I am missing.
1st RxPDO 0x1600
line 75
00 = sub index,
00 80 = value
00 = ????
The following user(s) said Thank You: Nico2017
- sqmathlete
13 Aug 2017 19:21 #97431
by sqmathlete
00 = offset?
Time to create page: 0.191 seconds
