- Thank you received: 18
Ethercat HAL driver
- sqmathlete
8 years 11 months ago #102235
by sqmathlete
Replied by sqmathlete on topic Ethercat HAL driver
Hi Frank,
This may be, however such wizardry is way over my head. That being said, I went back to the beginning and found a couple of errors in my xml code. After fixing those I followed Roschi's approach of using ladder logic to switch modes and initiate the homing routine.
All good so far, homing routine is now working. The next step is to modify the homing.c file except that the link which shows the modification to the homing.c file is gone.
docs.google.com/document/d/1GiB065ZIAaoM...xGQl2X9DM9-THNM/edit
Any suggestions?
Dan
If you want to interchange between 0x08 CSP mode to 0x06 Home mode, you have to code a state machine component which changes the op-state to pre-op state and then changes MODE OF OPERATION INDEX 0X6060 to whatever by SDO communication similar to github.com/sirop/MK_sdo_download/blob/master/sdo_download.comp .
Any suggestions?
Dan
- sirop
- Thank you received: 57
8 years 11 months ago - 8 years 11 months ago #102245
by sirop
Replied by sirop on topic Ethercat HAL driver
I am not Frank, but try
github.com/aschiffler/linuxcnc/blob/add-.../emc/motion/homing.c
I am curious what is
Can you give a link?
?Roschi's approach of using ladder logic to switch modes and initiate the homing routine
Last edit: 8 years 11 months ago by sirop.
- chimeno
- Thank you received: 125
8 years 11 months ago #102284
by chimeno
Replied by chimeno on topic Ethercat HAL driver
hello, sirop
Thank you very much, I will continue working if I get it to work.
- sqmathlete
8 years 11 months ago #102293
by sqmathlete
Hi Sirop,
My apologies for calling you Frank. Not sure how I got that idea...
In my opinion, Roschi would be the best person to explain how he managed to use custom M-codes and the file custom.clp
github.com/aschiffler/linuxcnc/tree/add-...t/configs/roschi_cnc to utilize the internal homing routine of the servo amp ... without LinuxCNC issuing a joint following error. It may be that he used absolute encoders? and I missed that too.
github.com/aschiffler/linuxcnc/commit/d2...c13f1761b5396aed364f
The homing.c file that you pointed to (which was the one that I was looking for, thanks) uses a home sequence of -1, which since the merge of JA and master now as you know means a synchronized final movement of two or potentially more joints. As a caveat, Delta amps require the host controller to be able to preform this type of routine before you can switch them to gantry mode where they will synchronize.
When, I say i used Roschi's approach what I meant was, that his example used an amp that used the Cia402 standard and I was able to work out the equivalent pins/parameters for my amplifier which using the new "complex" variable instead of the "special 32".
Our ladder logic programs are not similar but, I believe that end result is the same. I will post the clp file later today.
Conceptually the routine is
1) check mode (home = 6) (csp =
2) if you need to switch modes, inhibit, the enable pin (pin3 0x6040), wait for break to turn on
3) set the coils that are connected to 0x6060 pins 1,2,3 to set the mode
4) look for feed back from 0x6061 that the mode = 6
5) turn off the inhibit, amp is enabled
6) start home routine ... this is where I get a joint following error from LCNC
7) when the home routine is finished, reverse the proccess so that you end up in csp mode
My thoughts are that the addition of a new variable for home sequence might be required, i.e. to call a special case where you can deactivate the joint calculations/feedback?, tell lcnc that you are homing, allow the servo to do it's thing, lcnc can only estop at this point. Completion of homing subroutine sets the axis as homed and linuxcnc is now ready for auto mode.
This is theoretical only and perhaps trying to utilize the internal routines may be more effort than it is worth?
Any thoughts?
Dan
Any thoughts?
Dan
- sirop
8 years 11 months ago - 8 years 11 months ago #102294
by sirop
@sqmathlete
My applications never needed the CNC part of LinuxCNC and that's why I used my own homing components.
So I can not share any experience concerning Roschi's method.
- roschi
- Thank you received: 29
8 years 11 months ago #102301
by roschi
Replied by roschi on topic Ethercat HAL driver
Hi Dan,
some conceptional remarks for the work I have done.
- LinuxCNC do only send commanded values for the position (output of path planing) - No control loop in LinuxCNC is used, all Control is done by the servos. So also the observing of overtravel, folling error;
- Therefore the following error is ignored within the LCNC --> in the ini file set it to 99999999
- I have modified the "homing.c" with two short cuts in the state machine
- - first is for the case that the LinuxCNC starts the homeing sequence and all the rest is done by the servo. The servo sends a signal that he has finished. The signal is connected to the "classical homing switch" and so the LCNC is fine. (this case can be configured by using a special value for speed in the inifile -->9.9
-- second is the same except that there is no axis movement because there are absolut encoders (battery supply); set speed in ini file to 6.6 (search the code homing.c for 6.6 and 9.9 in my repository to get clear)
Hope that givessome hints.
Best Regards
Andreas
Best Regards
Andreas
The following user(s) said Thank You: sqmathlete, Nico2017
Time to create page: 3.026 seconds
