- Thank you received: 125
Ethercat HAL driver
- chimeno
8 years 8 months ago #105995
by chimeno
Replied by chimeno on topic Ethercat HAL driver
hi Siggi and Dan
Most modules are simple and the configuration that comes with "default" can be read through ethercat, terminal attachment with ethercat commands.
Dan you attached the example of EL9110 you can compare since it is a very easy module, the EL4004 module can be used without problems, any that works with protocol ethercat per operate!
Siggi the module EL5032 is a bit more complicated, I can help you, if you have it execute these commands and teach me and I'll give you a simple example.
I can not explain the whole process as it is complicated, I took a long time, but practice and with many hours you can get it !!
The TWINCAT3 application is the last one to perform configuration tests in more complicated modules that you have to configure using SOE or IDN also for the different PDO configurations, I also use TWINCAT3 with WIRESHARK to analyze the transmission of in the network, in the manuals of " Beckhoff's ELxxxx "is the procedure of how to insert and work with TWINCAT3.
Albert
Albert
The following user(s) said Thank You: sqmathlete, Nico2017
- Weiler810T
- Visitor
8 years 8 months ago #106069
by Weiler810T
Replied by Weiler810T on topic Ethercat HAL driver
I found this Predefined PDO Assignment for EL5032
infosys.beckhoff.com/index.php?content=..../2404455691.html&id=
Can you start something with it ?
- chimeno
8 years 8 months ago - 8 years 8 months ago #106150
by chimeno
Hello Weiler810T,
Here is the manual, download.beckhoff.com/download/document/...rminals/el5032en.pdf , it is best to proceed little by little, they may have multiple errors and you do not know where they come from, the best is that you connect the module to the pc and scans using the ethercat commands, if you do not install in TWINCAT3 windows connect the sensor to the module, insert it in a configuration and check it to work and read the input with a sensor you have, then you pass the configuration.
Chimeno
Weiler810T wrote: I found this Predefined PDO Assignment for EL5032
Hello Weiler810T,
Chimeno
Last edit: 8 years 8 months ago by chimeno.
- Weiler810T
- Visitor
8 years 8 months ago #106164
by Weiler810T
Hello
This is going to be a long time project, because I get a white beard and look like Santa Claus :blink:
Siggi
Hello Weiler810T,
Chimeno
Hello
Siggi
- chimeno
8 years 8 months ago #106250
by chimeno
Hello siggi,
you have the module EK1100 and the EL5032?, can I connect it and read the information?
Chimeno
Hello Weiler810T,
Chimeno
Hello
Siggi
Hello siggi,
Chimeno
- Weiler810T
- Visitor
8 years 8 months ago #106266
by Weiler810T
Hello Chimeno
No, I have to get the parts first, can take a while..
Siggi
Hello siggi,
Hello Chimeno
Siggi
Time to create page: 1.376 seconds
