Ethercat HAL driver
8 years 8 months ago - 8 years 8 months ago #105602 by chimeno
Replied by chimeno on topic Ethercat HAL driver
Hello Sirop,
Can you help me with the code ??, I have a problem when starting "rtai_app: caught signal 11 - dumping core"
The problem comes when I try to save code lines by using the for loop (i = 0, i <LCEC_EL3773_CHANS; i ++).
been doing latency tests
I do not have much difference between "generic driver" and "e1000e" I have a solution that seems to work, even in the testing phase.
configure EL3773
cycle 1000 us
  .ini file
servo_period = 500000
.xml file
appTimePeriod = "500000" refclocksyncCycles = "1000000"
DcConf assignActivate = "730" sync0cycle = "250000" sync0shift = "50000" sync1cycle = "750000" sync1shift = "500000"
my system
linux cnc 4.9.0-5-rt-686-pae # 1 SMP PREEMPT RT Debian 4.9.65-3-deb9u2 (2018-01-04) i686 GNU / Linux
Version IgH EtherCAT 1.5.2 1a7b3f94bdef +
Thank you
Chimeno
Last edit: 8 years 8 months ago by chimeno.
The following user(s) said Thank You: Nico2017
8 years 8 months ago - 8 years 8 months ago #105631 by sirop
Replied by sirop on topic Ethercat HAL driver
I never worked with this slave model so it is hard to say for me what goes wrong.
I wonder however if you could apply machinekit's debugging instructions github.com/mhaberler/asciidoc-sandbox/wi...ugging-RT-components in case of preeempt rt linuxcnc.
If so, you could see what causes "rtai_app: caught signal 11 - dumping core" .
Last edit: 8 years 8 months ago by sirop. Reason: typo
The following user(s) said Thank You: chimeno
  • Weiler810T
  • Visitor
  • Visitor
8 years 8 months ago #105689 by Weiler810T
Replied by Weiler810T on topic Ethercat HAL driver
Hello
I would like to read position data with the Beckhoff ek1100 and el5032 (endat) and make it available in linuxcnc(gmoccapy), is that possible?
Siggi
8 years 8 months ago #105690 by sirop
Weiler810T wrote: Hello
Siggi
Yes. el5032 might need "a generic slave" approach.
The following user(s) said Thank You: Weiler810T
8 years 8 months ago #105757 by chimeno
sirop wrote: I never worked with this slave model so it is hard to say for me what goes wrong.
hi Sirop,
thank you very much for the link is very interesting, I will study it .. I attach the last files that work well, I will continue studying ..
8 years 8 months ago #105759 by chimeno
Siggi
hello siggi,
As Sirop says it is possible and seeing the EL5032 manual has very good options.
Chimeno
Time to create page: 2.459 seconds
