- Thank you received: 18
Ethercat HAL driver
- sqmathlete
8 years 7 months ago #107970
by sqmathlete
Replied by sqmathlete on topic Ethercat HAL driver
@Chris B
Just a thought...what type of cables are you using to chain the servo's and the EK1100 Bus Coupler? Patch or Crossover?
- ChrisB
8 years 7 months ago - 8 years 7 months ago #108094
by ChrisB
Replied by ChrisB on topic Ethercat HAL driver
Hi
i use Patchcables.
Now i solved the problem more ore less. i changed the networkcard. i used the 8169 chip and now i use the 8193c with the 8139too kernel driver. I read that some people had problems with the 8169 chip.
Now the slaves are found by the cmd-ethercat-tool in any combination.
But up to now i am very close to get it running.
With a small sync problem oder config problem.
But i can't find the mistake.
When i start linuxcnc my kollmorgen S300 has an errror. F29 invalid ECAT actual-value mapping length
So it seems to be a problem with my xml config.
I attach my config and the output of the cmd tool and my hal and ini file. And the pdos output
And how can i config the dcsync?
The IO's work well
0 0:0 OP + EK1100 EtherCAT Coupler (2A E-Bus)
1 0:1 OP + EL1018 8Ch. Dig. Input 24V, 10�s
2 0:2 OP + EL1018 8Ch. Dig. Input 24V, 10�s
3 0:3 OP + EL1018 8Ch. Dig. Input 24V, 10�s
4 0:4 OP + EL2008 8Ch. Dig. Output 24V, 0.5A
5 0:5 OP + EL2008 8Ch. Dig. Output 24V, 0.5A
6 0:6 PREOP E S700 EtherCAT Drive (CoE)
i use Patchcables.
The IO's work well
Last edit: 8 years 7 months ago by ChrisB.
- sirop
- Thank you received: 57
8 years 7 months ago #108099
by sirop
and
So in both cases you map 16 bit pdoEntry to halType="bit" . Does this make sense?
I would use smth. like halType="u32" for control and status word, or if you need bitwise operation on control and status word,
then use halType="complex" as in github.com/sittner/linuxcnc-ethercat/blo...ercat-conf_X.xml#L98 .
Replied by sirop on topic Ethercat HAL driver
ChrisB wrote: Hi
i use Patchcables.
<pdoEntry idx="6040" subIdx="0" bitLen="16" halPin="Control_word" halType="bit"/>
<pdoEntry idx="6041" subIdx="0" bitLen="16" halPin="Status word" halType="bit"/>
- sqmathlete
8 years 7 months ago #108107
by sqmathlete
@ChrisB
I went through a similar issue a while back in this thread. My understanding is that if you see the slave in the PREOP state then you are able to communicate with the slave. I think that the problem is that you have not changed the amplifier control word (in hex) from
0x06 =>0x07=>0x0F,(in that order) i.e. you have not followed the 402 protocol to change the "state" to OP.
Try:
in xml file
define the control word
define the status word as u32 or complex depending on what you want to do with it
in hal
halcmd setp SwitchOn 1
halcmd setp EnableVoltage 1
net quickstop QuickStop => connected to estop chain via classicladder
net enable enableop => some pin that you can control with classicladder or linuxcnc enable pin
If you look at Sittner's hal file, he does it a little differently but I think the amp should switch to the OP state either way.
Regards,
Dan
Try:
in xml file
in hal
Regards,
Dan
The following user(s) said Thank You: Nico2017
- Ilya
8 years 6 months ago - 8 years 6 months ago #108251
by Ilya
Replied by Ilya on topic Ethercat HAL driver
Hello all
I installed your driver using deb repo.modusoft.de/linuxcnc/wheezy ./
My problem is running the program using "loadrt lcec" in the hal file.
I getting that:
Error: could not insert module /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/lcec.ko: Unknown symbol in module
I know little about this and I hope for Your help. Would you mind pointing me in the right direction?
ilya
__________________________________________
decided
I used a RTAi, whereas it was necessary to use RT-PREEMPT
I getting that:
ilya
decided
Last edit: 8 years 6 months ago by Ilya.
- ChrisB
8 years 6 months ago - 8 years 6 months ago #109007
by ChrisB
Thank you for your help.
i cant figure out the problem.
Datatype complex makes more sens, but this is not the problem.
i have two scenarios.
the first one is, if i use configpdos = false
Then linuxcnc does not stars and the debuginfo says failed to set safeop. 0x0017 invalid sync manager configuration.
The other one is configpdos = true
then the drives gets an error F29 invalid ECAT command-value mapping length.
can you imagine what the problem is?
Tanks
Tanks
Last edit: 8 years 6 months ago by ChrisB.
Time to create page: 2.182 seconds
