- Thank you received: 125
Ethercat HAL driver
- chimeno
7 years 6 months ago #130915
by chimeno
Replied by chimeno on topic Ethercat HAL driver
Hi guys,
added the module EL9110 to the standard configuration, greetings Chimeno
The following user(s) said Thank You: tommylight, CORBETT
- sqmathlete
- Thank you received: 18
7 years 6 months ago #130917
by sqmathlete
Replied by sqmathlete on topic Ethercat HAL driver
Awesome work!
- Grotius
- Thank you received: 2349
7 years 6 months ago #130918
by Grotius
Replied by Grotius on topic Ethercat HAL driver
chimeno,
How is github (sascha) responding to your new drivers?
We have to upload this to the sacha channel.
I think sacha must make you a member of his channel. Can you ask this to him?
- chimeno
7 years 6 months ago #130993
by chimeno
Hello Grotius, thanks for the compliments, but it's not that bad, I'm not an expert and I can not compare with Sascha, I just try to play a bit with linuxcnc and ethercat and learn a little more each day, I'll look if I can upload to the channel.
Chimeno
Chimeno
- chimeno
7 years 6 months ago #130994
by chimeno
Hi guys,
added the module EL9210 to the standard configuration, greetings Chimeno
The following user(s) said Thank You: tommylight, Grotius, CORBETT
- chimeno
7 years 6 months ago #131172
by chimeno
Hi guys,
added the module EL9410 to the standard configuration, greetings Chimeno
Time to create page: 0.540 seconds
