- Thank you received: 3
Ethercat HAL driver
- JimPanski
7 years 3 months ago #139158
by JimPanski
Replied by JimPanski on topic Ethercat HAL driver
Hello,
i sucessfully installed the linuxcnc ethercat drivers and managed to get it work with EK1100 and some EL1004 Inputs. Problem is, that i have KL modules here which i have to use. Now i cant use the KL modules without a coupler for the K-Bus modules. At the moment i dont have one.
Can anyone here say if its possible to use also those K-Bus components with eg. a BK1150? (togehter with my existing/already working EK1100 or E-Bus modules)
Thank you very much for the answers! I will post also a new thread for the machine which i want to equip with these things
Cheers
Conny
Cheers
Conny
- chimeno
- Thank you received: 125
7 years 3 months ago - 7 years 3 months ago #139202
by chimeno
Replied by chimeno on topic Ethercat HAL driver
Hello Jim Panski,
the K-BUS protocol I looked at it a long time ago, it's not compatible, maybe someone knows something else about it.
Chimeno
Chimeno
Last edit: 7 years 3 months ago by chimeno. Reason: Edit
- cheng
- Thank you received: 9
7 years 3 months ago #139944
by cheng
Replied by cheng on topic Ethercat HAL driver
Hello, can you leave your contact information? QQ or Facebook account。
I'd like to ask you some questions
- chimeno
7 years 3 months ago #140665
by chimeno
The following user(s) said Thank You: tommylight, Nico2017, Grotius, CORBETT
- Grotius
- Thank you received: 2349
7 years 3 months ago #140688
by Grotius
Replied by Grotius on topic Ethercat HAL driver
Thank you Chimeno for your excellent work,
EL3773 | Power monitoring oversampling terminal
The EtherCAT Terminal EL3773 is a power monitoring terminal for state monitoring of a 3-phase AC voltage system. For each phase voltages up to 288 Veff/410 V DC and currents up to 1 Aeff/1.5 A DC are sampled as instantaneous values with a resolution of 16 bits. The six channels are measured simultaneously based on the EtherCAT oversampling principle with a temporal resolution of up to 100 µs and passed on to the control system. The control system has sufficient computing power for true RMS or performance calculation and complex custom algorithms based on the measured voltages and currents. Through the oversampling principle the terminal is able to measure at significantly shorter intervals than the cycle time of the control system. AC and DC parameters must be connected and measured with a common reference potential. The EL3773 supports distributed clocks and can therefore measure synchronous with other EtherCAT devices.
The following user(s) said Thank You: chimeno, tommylight, Nico2017
- Thank you received: 7491
7 years 3 months ago #140691
Replied by tommylight on topic Ethercat HAL driver
That is interesting, especially here as the mains fluctuate a lot.
Time to create page: 1.049 seconds
