- Thank you received: 125
Ethercat HAL driver
- chimeno
Chimeno
- Grotius
- Thank you received: 2349
Thanks dude. This is perfect !!
Did you ever tried the etherlab.org/en/ethercat/ driver and edit a simple example?
This is very nice to test for embedded application's with QT interfacing. Very, very powerfull !!
( for readers, this has nothing to do with linuxcnc. It's a stand alone application based on fast protocol and high end HMI, used in this submarine for example : )
- bkt
- Thank you received: 114
Can anyone reply to me about? Thanks! The link of mine probabily wrongplace to post (here in lcnc forum).
- ryucz
I have a bus coupler BK1120 for them. Up and running in TwinCAT everything is working fine.
BUT
I sucessfully installed linuxcnc-ethercat and i can see my coupler in slaves. I've read somewhere, that K-Bus is not "transparent" to ethercat master, so i guess that's why i see ONLY my coupler.
Looking through code of linuxcnc-ethercat, it seems to have compatibility only for E-Bus devices (EL.... etc)
Is there any possibilty to "talk" with K-Bus terminals and coupler?
- CORBETT
- Thank you received: 113
I finally have my Hurco KMB1 running again. It took quite a bit to totally figure everything out, but I absolutely love the EtherCAT setup. Just ran the first part program through today. I will post pictures in a few weeks of my setup. About to start retrofitting the second machine with the same setup.
Dan (sqmathlete),
You were correct, I needed to read a LOT more about the whole concept and it took time but glad to have the machine running again.
Thanks,
Robert
- chimeno
Grotius wrote: Hi Chimeno,
hello Groutis, if at the beginning you provide an example of code to handle a servodrive, but since I'm not programmed it's easier for me with the sittner code, regards
Chimeno
