Ethercat HAL driver
6 years 8 months ago #157748 by chimeno
Replied by chimeno on topic Ethercat HAL driver
The EL2521 has four different variants:
EL2521-0000, EL2521-0024, EL2521-0124, EL2521-0025
download.beckhoff.com/download/document/...rminals/el252xen.pdf <= English version
download.beckhoff.com/download/document/...rminals/el252xde.pdf <= German version
Are these four versions identical regarding their software driver ? Or should I pick a certain one ?
Hello @mh , according to the manual they seem the same except that the outputs are different and you will have to choose the one that suits you, I do not think you have a problem with any version
And has anybody tried the two channel EL2522 perhaps ? Or are they not supported yet ?
EL2522 there is no driver in linuxcnc-ethercar, you will have to use the generic one, I don't have it but I don't think I have problems with both channels.
Chimeno
6 years 8 months ago - 6 years 8 months ago #157759 by jirkam
Replied by jirkam on topic Ethercat HAL driver
Please don't have a .xml file for EL4004? I still have EL4004 "PREOP".
Other modules I have "OP"
I have read the instructions in my language and it is beyond my possibilities.
Thank you very much.
Last edit: 6 years 8 months ago by jirkam.
6 years 8 months ago #157902 by chimeno
Hi @jirKam,
Just add this line.
<slave idx="1" type="EL4004" name="EL4004"/>
greeting
Chimeno
6 years 8 months ago - 6 years 8 months ago #157903 by jirkam
Hello.
In the .xml file I have:
<masters> <master idx="0" appTimePeriod="1000000" refClockSyncCycles="1000"> <slave idx="0" type="EK1100" name="EK1100"/> <slave idx="1" type="EL1819" name="DIN1"/> <slave idx="2" type="EL1819" name="DIN2"/> <slave idx="3" type="EL2809" name="DOUT1"/> <slave idx="4" type="EL3064" name="AIN"/> <slave idx="5" type="EL4004" name="AOUT"/> <slave idx="6" type="EL2622" name="RELE1"> <dcConf assignActivate="300" sync0Cycle="*1" sync0Shift="-25000"/> </slave> </master> </masters>
but for EL4004 I'm still in PREOP mode. The other modules are OP.
And I do not know why.
For compilation I gave:
cd linuxcnc-ethercat sudo make clean sudo make -j4 cp src/lcec.so ~/linuxnc-dev/rtlib/ sudo make install
Everything went without error.
I thought you needed to sign another .xml file.
Like this:
https://docs.google.com/document/d/1GiB065ZIAaoMHPtVfTg9JV1Kn-19xGQl2X9DM9-THNM/edit
Thank you.
6 years 8 months ago #157933 by chimeno
Hi @jirKam,
EL2622 is a relay output device does not require DC mode, can you try it again?
<masters> <master idx="0" appTimePeriod="1000000" refClockSyncCycles="1000"> <slave idx="0" type="EK1100" name="EK1100"/> <slave idx="1" type="EL1819" name="DIN1"/> <slave idx="2" type="EL1819" name="DIN2"/> <slave idx="3" type="EL2809" name="DOUT1"/> <slave idx="4" type="EL3064" name="AIN"/> <slave idx="5" type="EL4004" name="AOUT"/> <slave idx="6" type="EL2622" name="RELE1"/> </master> </masters>
without or it works, you can pass me the linuxcnc-ethercat folder to see how the EL4004 controller is described.
Greeting
Chimeno
6 years 8 months ago #157936 by jirkam
Hello.
Still is PREOP.
This is a test version.
The final version will be:
<masters> <master idx="0" appTimePeriod="1000000" refClockSyncCycles="1000"> <slave idx="0" type="EK1100" name="EK1100"/> <slave idx="1" type="EL1819" name="DIN1"/> <slave idx="2" type="EL1819" name="DIN2"/> <slave idx="3" type="EL2809" name="DOUT1"/> <slave idx="4" type="EL2809" name="DOUT2"/> <slave idx="5" type="EL3064" name="AIN"/> <slave idx="6" type="EL4004" name="AOUT"/> <slave idx="7" type="EL2622" name="RELE1"/> <slave idx="8" type="EL2622" name="RELE2"/> <slave idx="9" type="EL2622" name="RELE3"/> <slave idx="10" type="EL2622" name="RELE4"> <dcConf assignActivate="300" sync0Cycle="*1" sync0Shift="-25000"/> </slave> <slave idx="11" type="DeASDA" name="X"> <dcConf assignActivate="300" sync0Cycle="*1" sync0Shift="-25000"/> </slave> <slave idx="12" type="DeASDA" name="Y1"> <dcConf assignActivate="300" sync0Cycle="*1" sync0Shift="-25000"/> </slave> <slave idx="13" type="DeASDA" name="Y2"> <dcConf assignActivate="300" sync0Cycle="*1" sync0Shift="-25000"/> </slave> <slave idx="14" type="DeASDA" name="Z"> <dcConf assignActivate="300" sync0Cycle="*1" sync0Shift="-25000"/> </slave> <slave idx="15" type="DeASDA" name="A"> <dcConf assignActivate="300" sync0Cycle="*1" sync0Shift="-25000"/> </slave> </master> </masters>
Jirka
Time to create page: 0.568 seconds
