- Thank you received: 9
Ethercat HAL driver
- jirkam
6 years 8 months ago #158221
by jirkam
Replied by jirkam on topic Ethercat HAL driver
Hello.
I tried another order of modules.
But still PREOP
Can you think of any solution?
Thank you very much.
Jirka
But still PREOP
Jirka
@CNCRouter:~$ ethercat slaves
0 0:0 OP + EK1100 EtherCAT-Koppler (2A E-Bus)
1 0:1 PREOP + EL4004 4K. Ana. Ausgang 0-10V, 12bit
2 0:2 OP + EL3064 4K.Ana. Eingang 0-10V
3 0:3 OP + EL2622 2K. Relais Ausgang, Schlie�er (230V AC / 30V DC)
1 0:1 OP + EL1819 16K. Dig. Eingang 24V, 10�s
2 0:2 OP + EL1819 16K. Dig. Eingang 24V, 10�s
3 0:3 OP + EL2809 16K. Dig. Ausgang 24V, 0.5A
4 0:4 OP + EL3064 4K.Ana. Eingang 0-10V
5 0:5 PREOP + EL4004 4K. Ana. Ausgang 0-10V, 12bit
6 0:6 OP + EL2622 2K. Relais Ausgang, Schlie�er (230V AC / 30V DC)
- jirkam
6 years 8 months ago #158228
by jirkam
Hi
Maybe the problem is here?
- Thank you received: 7491
6 years 8 months ago #158230
Replied by tommylight on topic Ethercat HAL driver
The first error is regarding an AMD Radeon graphic card, most probably a flashed card used for mining.
The last error is most probably due to an invalid entry in the /etc/fstab, usually searching for a partition that was there during install and now missing. A quick fix for that would be to edit the /etc/fstab and omit all the lines under the main partition line, save and reboot.
- jirkam
6 years 8 months ago #158231
by jirkam
Hi.
Comment on the last two lines (#)?
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
# / was on /dev/sda1 during installation
UUID=d0e2d0a5-0ec2-4cdd-a552-73b48fbe497d / ext4 errors=remount-ro 0 1
# swap was on /dev/sda5 during installation
UUID=a124b862-e3c6-4322-9608-0c85930116c2 none swap sw 0 0
/dev/sr0 /media/cdrom0 udf,iso9660 user,noauto 0 0
6 years 8 months ago #158233
Not the first, just the second.
If you omit the first one the computer will not boot complaining about missing root partition.
- jirkam
6 years 8 months ago #158234
by jirkam
I wouldn't like that.
Thus?
I'd hate to ruin something.
Thus?
#UUID=a124b862-e3c6-4322-9608-0c85930116c2 none swap sw 0 0
Time to create page: 0.889 seconds
