Ethercat HAL driver
6 years 2 months ago - 6 years 2 months ago #177262 by bkt
Replied by bkt on topic Ethercat HAL driver
@ thang -> Just try on ubunto 64bit ... not work for me ... [strike]to morrow i try on debian install.[/strike] i remember I have a pc with debian linuxcnc strch ready ... so I try just now ... not work ... and reading some my old post I remember that these suggestion is not working for me 3/4 days ago.
bkt
Last edit: 6 years 2 months ago by bkt. Reason: no write .hgrc file so I gave an error that is report erroneusment
6 years 2 months ago - 6 years 2 months ago #177487 by bkt
@thang ... i undesrtand I revert a wrong file .... [strike]but I didn't understand how the realtime.mk file should be written ..[/strike]
the file to revert is realtime.mk .... so
  1. cd linuxcnc-ethercat/src
  2. gedit realtime.mk (clear all world in file and add these file .... after save and close ... copy the code I pasted below it comes from version 0.9.1 linuxcnc-ethercat)
  3. after these meke and make install for linuxcnc-ethercat
include ../config.mk include Kbuild include $(MODINC) ifeq ($(BUILDSYS),kbuild) # dirty workaround to get the RTAI directory RTAIINCDIR = $(subst /rtai.h,,$(firstword $(wildcard $(foreach i,$(subst -I,,$(filter -I%,$(RTFLAGS))), $(i)/rtai.h)))) ifneq ($(RTAIINCDIR),) RTAIDIR = $(realpath $(RTAIINCDIR)/..) endif all: $(MAKE) EXTRA_CFLAGS="$(EXTRA_CFLAGS)" KBUILD_EXTRA_SYMBOLS="$(RTLIBDIR)/Module.symvers $(RTAIDIR)/modules/ethercat/Module.symvers" -C $(KERNELDIR) SUBDIRS=`pwd` CC=$(CC) V=0 modules else LDFLAGS += -Wl,-rpath,$(LIBDIR) -L$(LIBDIR) -llinuxcnchal -lethercat all: modules endif
very thanks @thang
bkt
6 years 2 months ago #178352 by JKAVS
Replied by JKAVS on topic Ethercat HAL driver
I’m building a CNC mill and would like to have a fieldbus based control system. Ethercat with Linuxcnc seems to be one way to do it.
It looks like ASDA series servo drives from Delta are supported by this driver. Does the support include all models? I’m planning to use ASDA-B3. If they are not yet supported, how hard is it to add support for them?
Can the spindle speed be controlled with Ethercat? I’m guessing at least analog control with 0-10 volt signal is possible.
Are there any caveats in using this approach to build the control system? My goal is to make the control system simpler with Ethercat. If this would lead to overly complicated system then I’m looking somewhere else.
6 years 2 months ago #178357 by pippin88
Replied by pippin88 on topic Ethercat HAL driver
I'm also interested in Ethercat for Delta ASDA-B3 servos.
My understanding is I would only need:
LinuxCNC computer
Delta servos
(no other specialty cards unless I want more IO than the delta servos have)
I'm coming from using Mesa 7i76 for steppers.
6 years 2 months ago #178361 by JKAVS
That’s why I’m so interested in this. Just computer and drives would be so much easier than motion controller, breakout board, drives, multiple power supplies and so on.
6 years 2 months ago #178374 by pippin88
Also, is there any issues with using Ethercat driver and Mesa boards in the same setup (I think not but just checking)?
Time to create page: 0.358 seconds
