- Thank you received: 125
Ethercat HAL driver
- chimeno
6 years 5 months ago - 6 years 5 months ago #168902
by chimeno
Replied by chimeno on topic Ethercat HAL generic on raspberry 4 rt (working with beckhoff)
Hi @sqmathlete
You can add all the PDOs that the controller supports, it would be the same way as the default ones.
If you have TWINCAT3 it is easy to test all the supported PDOs
reguard
Chimeno
reguard
Chimeno
Last edit: 6 years 5 months ago by chimeno. Reason: Edit
- sqmathlete
- Thank you received: 18
6 years 5 months ago #168971
by sqmathlete
Replied by sqmathlete on topic Ethercat HAL generic on raspberry 4 rt (working with beckhoff)
@ chimeno
Sorry, I was unclear. I meant in the source file lcec_deasda.c.
Also,can you explain how you determined the scale value for this
Dan
<pdoEntry idx="6064" subIdx="00" bitLen="32" halPin="actpos" halType="float" scale="1.192092896e-6"/>
Dan
- chimeno
6 years 5 months ago - 6 years 5 months ago #168994
by chimeno
Hi @sqmathlete
I don't know if this is what you need ?? If you have the device's .xml description file, I can see it in TWINCAT3 that PDO you need
Reguard
Chimeno
The value I did not look for it, is from a previous publication by @theshadeAdemás, ¿puede explicar cómo determinó el valor de escala para este
<pdoEntry idx = "6064" subIdx = "00" bitLen = "32" halPin = "actpos" halType = "float" scale = "1.192092896e-6" />
PDOs are defined in lines 194-199, you also have to modify lines 122-148 and put the number of maximum PDOs in the .h file #defineSorry, I was unclear. I meant in the source file lcec_deasda.c.
LCEC_DEASDA_PDOS 6
Reguard
Chimeno
The following user(s) said Thank You: sqmathlete
- chimeno
6 years 5 months ago - 6 years 5 months ago #169002
by chimeno
Last edit: 6 years 5 months ago by chimeno. Reason: Edit .xml
The following user(s) said Thank You: CORBETT
- theshade
- Thank you received: 5
6 years 5 months ago - 6 years 5 months ago #169035
by theshade
Replied by theshade on topic Ethercat HAL generic on raspberry 4 rt (working with beckhoff)
Hello @ chimeno,
I made some progress yesterday. When I start linuxcnc my device goes into OP and now if I write this in a terminal.
The motor gets current and I can't turn it by hand anymore:
But how and where should I have this in linuxcnc?
[update] I think there are plenty of examples in here: github.com/aschiffler/linuxcnc/tree/master/configs/roschi_cnc
I will try to adapt sth from this in the hal file...
Also I think my "scaling" is currently wrong, I think the encoders are 1000 steps per rev while the stepper is actually 200 steps per rev.. and I will attach some SFU1605 screws to them.
Thank you again for your support
ethercat -p0 -t uint16 download 0x6040 0 0x0006 # EnableVoltage+QuickStop
ethercat -p0 -t uint16 download 0x6040 0 0x0007 # +SwitchOn
ethercat -p0 -t uint16 download 0x6040 0 0x000f # +EnableOperation
setp lcec.0.3.drivecontrol-8 1
setp lcec.0.3.drivecontrol-13 1
setp lcec.0.3.drivecontrol-14 1
setp lcec.0.3.signalcontrol-0 0
setp lcec.0.4.drivecontrol-8 1
setp lcec.0.4.drivecontrol-13 1
setp lcec.0.4.drivecontrol-14 1
setp lcec.0.4.signalcontrol-0 0
setp lcec.0.5.drivecontrol-8 1
setp lcec.0.5.drivecontrol-13 1
setp lcec.0.5.drivecontrol-14 1
setp lcec.0.5.signalcontrol-0 0
Last edit: 6 years 5 months ago by theshade.
- chimeno
6 years 5 months ago - 6 years 5 months ago #169148
by chimeno
Hi @theshade
I do not use this type of generic file, it costs me a bit, and without having the device it is also a little more difficult
I attach a new .xml file with some changes
a your .hal file
Now the driver is ready to work ...
the scale is surely wrong if not calculated, but to start leave at 1 and then check the measurement
Could this be the scale?
Now we connect the signals ...
I hope it is a good start ...
Reguard
Chimeno
a your .hal file
setp lcec.0.X-cmd-SwitchOn 1
setp lcec.0.X-cmd-EnableVoltage 1
setp lcec.0.X-cmd-/QuickStop 1
setp lcec.0.X-cmd-EnableOperation 1
<pdoEntry idx="607A" subIdx="00" bitLen="32" halPin="poscmd" halType="float" scale="40.0"/>
<pdoEntry idx="6064" subIdx="00" bitLen="32" halPin="actpos" halType="float" scale="200.0"/>
lcec.0.poscmd -> joint.0.motor-pos-cmd
lcec.0.actpos <- joint.0.motor-pos-fb
Reguard
Chimeno
Time to create page: 2.083 seconds
