- Thank you received: 7491
Notes from installation of ethercat on Raspberry Pi 4
2 years 4 months ago #302393
RTAI version is more for use with parallel port.
Replied by tommylight on topic Notes from installation of ethercat on Raspberry Pi 4
This can be used to control machines when using the RT-Preempt kernel, it can not be used to control machines when using normal "generic" kernel.“linuxcnc-uspace” will also run on a standard Linux kernel for use as a simulator, but it should not be used to control hardware."
- seyad
2 years 3 months ago #304732
by seyad
Replied by seyad on topic Notes from installation of ethercat on Raspberry Pi 4
- Thank you received: 4153
2 years 3 months ago #304733
Replied by rodw on topic Notes from installation of ethercat on Raspberry Pi 4
3 years is a long time in this space.
I would try installing the Raspberry pi 5 image on the downloads page and then follow these instructions
forum.linuxcnc.org/ethercat/45336-etherc...-how-to-step-by-step
The ethercat repositories should be installed for you already so hopefully, you will find there is no need to build from source if iGh supports the pi5 now.
The following user(s) said Thank You: seyad
- seyad
2 years 3 months ago #306513
by seyad
At the point of "Test ethercat with linuxcnc " i am facing issues like "lFound file(REL): ./ethercat.hal
lcec: dlopen: libethercat.so.1: cannot open shared object file: No such file or directory"
But path my directory (path=$PATH:/usr/local/lib)
- bkt
- Thank you received: 114
2 years 3 months ago #306547
by bkt
Replied by bkt on topic Notes from installation of ethercat on Raspberry Pi 4
you check id uefi or not as rodw explain here:
In my case need (not uefi but have that error because not all libs needed was installed) to install libethercat 2 time second one using synaptic. After it goes ....
2 years 3 months ago #306560
Thanks for reminding me of this. This is probably the issue I have with installing ethercat.
The following user(s) said Thank You: bkt
Time to create page: 0.222 seconds
