Notes from installation of ethercat on Raspberry Pi 4
2 years 1 month ago #309596 by bertoldo
I verifid the image download and is corrupt. Downlad a twice but result is same. You have other image?
2 years 1 month ago #309712 by seyad
are you using this image ? www.linuxcnc.org/iso/rpi-4-debian-bookwo...23-11-17-1731.img.xz . are you using this( www.raspberrypi.com/software/ ) application for preparing your sd-card..? RAM size of your rpi above 4GB means good.
2 years 1 month ago #309733 by bertoldo
Good morning!
I am using the image from the link that started the forum about ethercat. My raspberry has 8 gigabytes and a 64 gigabyte SD card... and I use the raspberry image to generate the boot. I downloaded this file from the link you sent me now and the error is the same. If I try to open the image, it says that the file is corrupted.
2 years 1 month ago - 2 years 1 month ago #309751 by jjdege
Good morning!
Hello
the micro SD is very fragile, nothing is enough and it is no longer usable,
the installation with Raspberry Image is successful but the system does not start, I burned three,
with the installation directly on NVMe M2 and adapter
in my case, I solved it, I do not know if the problem is the same
I reinstalled several times without problems
Last edit: 2 years 1 month ago by jjdege.
2 years 1 month ago #309752 by bertoldo
Thanks for the answer.
but the issue I see and that makes me suspicious is that I download the image on a PC with W10 and I can't open it. It says it's corrupted, I can't even open it.
2 years 1 month ago #309758 by jjdege
Hi
I did a test:
I downloaded the image from here with W10
I opened it with Raspberry Image
it loads without problems
The following user(s) said Thank You: tommylight, Aciera
Time to create page: 0.341 seconds
